March 16, 2025, 08:31:32 PM
General
General Discussion
Ballasting a burned out SBMV?
Topic: Ballasting a burned out SBMV? (Read 799 times)
RadiantMV
« on: January 14, 2022, 03:24:25 PM »
RadiantMV
Since SBMV bulbs burn out due to the filament breaking and not the arc tube failing, would it be possible to ballast the arc tube using a standard mercury vapor ballast once the filament has run its course?
Re: Ballasting a burned out SBMV?
« Reply #1 on: January 14, 2022, 04:48:58 PM »
Not unless you're able to connect the two points where the filament was together, it's in series with the arctube and when it breaks it will create an open circuit regardless of what kind of ballast you try.
Unofficial LG Discord
