Author Topic: failed HID lamps on LED retrofitted fixtures that have the ballast bypassed  (Read 1123 times)
failed HID lamps on LED retrofitted fixtures that have the ballast bypassed « on: December 14, 2021, 07:13:53 PM » Author: WorldwideHIDCollectorUSA
Has anyone seen any LEDized HID fixtures that contain failed HID lamps as a result of the ballast being bypassed before? In those situations, I would figure that some electricians might inadvertently replace a failed corncob with a HID lamp after seeing the ANSI code written on the fixture.
Econolite03
Matthew E.
Re: failed HID lamps on LED retrofitted fixtures that have the ballast bypassed « Reply #1 on: December 14, 2021, 08:52:46 PM » Author: Econolite03
Not that I know of.
Re: failed HID lamps on LED retrofitted fixtures that have the ballast bypassed « Reply #2 on: December 14, 2021, 11:08:51 PM » Author: funkybulb
A good sparky would do a visual inspection of lume to see if it has a ballast or not.   And even look if it funtional to replace a hid lamp.
  Pulse start lamps many time just wont start with out a ignitor anyways when it bypass.  But probe start will thermally runnaway
Re: failed HID lamps on LED retrofitted fixtures that have the ballast bypassed « Reply #3 on: December 14, 2021, 11:35:44 PM » Author: WorldwideHIDCollectorUSA
You could see that happening with a mercury vapor lamp installed.
Re: failed HID lamps on LED retrofitted fixtures that have the ballast bypassed « Reply #4 on: December 15, 2021, 02:25:06 AM » Author: Medved
On 230V and mainly with higher power (so beefier) lamps the result is often just a tripped breaker and the lamp surviving. Apparently the current becomes so hogh so quickly the breaker trips way before the lamp components melt. Had even a 125W MV that "survived" quite a few attempts to install into incandescent fixture and worked for quite a long time afterwards.
Of course, "often" by far does not mean "always"...
And indeed a good sparkie won't just blindly replace the bulb but really diagnose what really had failed...
Re: failed HID lamps on LED retrofitted fixtures that have the ballast bypassed « Reply #5 on: December 15, 2021, 02:31:02 AM » Author: WorldwideHIDCollectorUSA
A breaker might even trip on 208v mains too since most mercury vapor lamps need an OCV of about 200v to start and operate.
