Author Topic: Dying CFL  (Read 4623 times)
Mr. Big
Dying CFL « on: September 07, 2009, 02:58:48 PM » Author: Mr. Big
Here's a CFL burnout you might enjoy! http://s337.photobucket.com/albums/n393/RCM442/?action=view&current=Picture075.flv
Re: Dying CFL « Reply #1 on: September 07, 2009, 03:43:59 PM » Author: Medved
It was unusually peaceful dying...
Mr. Big
Re: Dying CFL « Reply #2 on: September 07, 2009, 04:21:15 PM » Author: Mr. Big
Surprising huh?
Re: Dying CFL « Reply #3 on: September 07, 2009, 04:28:30 PM » Author: Medved
I'm used to orange flashing, then big BANG and darkness, as the circuit breaker trip...
Well, filament lamps do usually flash, then big BANG and darkness, as the circuit breaker trip, so no big difference here...
Mr. Big
Re: Dying CFL « Reply #4 on: September 07, 2009, 06:20:16 PM » Author: Mr. Big
In my case, I've only had one CFL trip a breaker, it was a GE daylight
lite_lover
Darren
GoL darren.harward
Re: Dying CFL « Reply #5 on: September 08, 2009, 02:16:01 AM » Author: lite_lover
I see there was a small arc flash and pop inside near the end,was that the capacitor?
The brighter the better.
Re: Dying CFL « Reply #6 on: September 08, 2009, 01:50:50 PM » Author: Medved
No, capacitor die independently of the tube. It was or glass cracking or transistors and the mains fuse - in such regime transistors overheat, fail short circuity and then the fuse has to act and disconnect the supply.
And here came (one hypothesis i got recently) the difference between 120V and 230V designs:
As 230V designs use bridge rectifier, such transistor short cause very huge (virtually unlimited) current flowing from the mains (>10A), so there is enough margin to blow the fuse.
But on 120V designs there is voltage doubler, where 2 diodes from above are replaced by 2 capacitors. When the DC output is shorted by dying transistors, the current is limited by capacitor's impedance, so might stay low enough (<1A), so the fuse does not act. But even with such relatively low current, the power dissipated is very large (1A cause up to 120W dissipation), what turn into heat in the ballast compartment (designed for <1W normal operation power dissipation), so it overheat, start to smoke or set a fire.
And as fuses have quite some tolerance, they have to be designed so, under normal operation they never trip, even if the tolerance cause the trip current is on it's minimum. But this mean, then it's maximum is much higher then operating current, usually >5x. But with the doubler (limited failure current) this mean, then the fuse might not trip at all, so we have a fire.
The cure would be adding two diodes, each in parallel with one doubler's capacitor, so when the short appear, these diodes ensure high enough failure current, so the fuse reliably trip. But these diodes cost a cent each, so are often assumed as too expensive for components what normally have no function, so omitted...
Mr. Big
Re: Dying CFL « Reply #7 on: September 08, 2009, 07:29:36 PM » Author: Mr. Big
No, it was a transistor, a cap popping is louder!
