Author Topic: Should I be ashamed to say that I like LED's?  (Read 4621 times)
Re: Should I be ashamed to say that I like LED's? « Reply #15 on: October 08, 2021, 08:15:39 PM » Author: Mandolin Girl
That's what happens when the font the site uses doesn't have any serifs...  :mrg:
Re: Should I be ashamed to say that I like LED's? « Reply #16 on: October 08, 2021, 08:20:01 PM » Author: wide-lite 1000
It's a lowercase "L". It was just a typo.
 I figured it was but the smart a** in me couldn't help but to come out !  :lol:  :eoled:  And I agree with Ria ,  if I was given no choice in what lamps I could or couldn't use I'd more than likely hate LEDs a lot more than I do !
Econolite03
Matthew E.
Re: Should I be ashamed to say that I like LED's? « Reply #17 on: October 08, 2021, 08:36:11 PM » Author: Econolite03
Yeah pretty much California banned almost everything non-LED. However most of the halogens that were sold here in their final days I wasn’t impressed with. But I do agree on having more options if desired.
Speaking of getting stuff from other states, recently I had to buy banned lawn sprinklers from out of state due to CA regulations.
waterbug
Re: Should I be ashamed to say that I like LED's? « Reply #18 on: October 09, 2021, 01:34:03 AM » Author: waterbug
The title says it all. I just hope that I won't be criticized for liking them.
I like some led too but hate most of them, especially :led: street lights and :led: high mast lighting. I'm ok with buying the ones with 16 million color where I can change color and brightness via WiFi/bluetooth connection. If I were given one option to save a lamp, option 1 being 10 Philips HUE inside a box,option B is one piece of 90w :lps: NOS fabricated in 1984, I'll take the :lps: without hesitation. No regrets bro
Re: Should I be ashamed to say that I like LED's? « Reply #19 on: October 09, 2021, 01:56:48 AM » Author: AngryHorse
Personally, the LED lamps that I prefer using are plug and play LED retrofit lamps for HID and preheat fluorescent fixtures because they are designed to be used in traditional fixtures without having to modify the wiring to such a degree that I can easily change back to traditional light sources if I wanted to. I also enjoy the same with ballast bypass LED retrofit lamps such as the lED corn cob lamps because I can change the lamp back to HID if I wanted to. Personally, the only types of LED lighting that I really dislike are integrated LED fixtures and LED retrofit modules that have integrated LEDs inside them, and ballast bypass LED lamps that do not use a screw base or bayonet base.
Integrated units are alright when they work!, I’ve just fitted 31 integrated units whilst doing an upgrade on our valet bay canteen, 2 did indeed fail out of the box, however there’s a 5 year warranty on them, and our wholesale says they have to honour this, and will replace dead units without question within that 5 years!
That’s not bad, (although a pain in the ****), to keep taking them back!, but usually I do prefer a ‘lamp and fitting’ set up personally, but I’m keeping a record of how many will fail now in those next 5 years.
Current: UK 230V, 50Hz
Power provider: e.on energy
Michael
Re: Should I be ashamed to say that I like LED's? « Reply #20 on: October 09, 2021, 02:59:08 AM » Author: Michael
I do like LED as well but what I don’t like is how these are being pushed and praised on the market to be the best solution ever invented and everything which is non LED is being very terribly bad for the environment, health and safety.
I’m glad that in general all utility companies here are using rather well built LED street lights and I’m also satisfied that I finally found the proper plug- in LEDs for our older streetlights.
Re: Should I be ashamed to say that I like LED's? « Reply #21 on: October 09, 2021, 08:08:45 AM » Author: Mandolin Girl
@ AngryHorse:
Okay, so picture the scene one year down the line when one of the units fails and you send it back to be replaced and you're told that that particular fitting has been discontinued and the replacement looks nothing like what you have installed. What do you do then...  :wndr:
This actually happened to Tim (Widelite) and he was not a happy bunny...  :curse:
« Last Edit: October 09, 2021, 08:18:48 AM by Mandolin Girl » Logged
Re: Should I be ashamed to say that I like LED's? « Reply #22 on: October 09, 2021, 08:33:35 AM » Author: AngryHorse
Whether in intergrated form, or in GU10 and MR16 their all still industry standard 50mm multifaceted reflector units, even if that particular model gets discontinued, the new version will still be a 50mm multifaceted reflector light source, whatever name brand is on it, you will always be able to get them.
« Last Edit: October 09, 2021, 08:38:31 AM by AngryHorse » Logged
Re: Should I be ashamed to say that I like LED's? « Reply #23 on: October 09, 2021, 08:35:28 AM » Author: Mandolin Girl
Agreed, but if the trim looks significantly different, the replacement will stand out.  :curse:
Re: Should I be ashamed to say that I like LED's? « Reply #24 on: October 09, 2021, 08:46:50 AM » Author: AngryHorse
But again, the trim size is also standard to fit the 50mm, whether it’s white, chrome, gold or other colours, however, I agree in a house where you would normally have just 4 to 6 downlighting, a unit that’s not exactly matched would indeed stand out?
In commercial premises where large numbers are in use, to the average worker sitting in their canteen, they probably wouldn’t notice ( or even care ), about the lighting!
There’s 3 different models of six foot twin LED battens in our main workshop, but there’s usually only me that can point them out!
Re: Should I be ashamed to say that I like LED's? « Reply #25 on: October 09, 2021, 08:51:03 AM » Author: sox35
That was Tim's problem, as I recall. He had three downlighters outside his front door, on the porch, or wherever it was. One failed, so he went to the store to get another and was told it was no longer available, and the only similar one looked totally different.
It's like re-lamping with different colour temperature lamps; the one that's different stands out a mile; it is noticeable, and would annoy the hell out of me  :curse:
fluorescent lover 40
Re: Should I be ashamed to say that I like LED's? « Reply #26 on: October 09, 2021, 10:40:39 AM » Author: fluorescent lover 40
LightsoftheWest - No, you shouldn't. Like High Intensity said, you are entitled to like whatever light source you like.
I like LEDs too. Just hate the integrated and the cheap stuff. I'm getting used to the LED street lights and starting to like them.
Re: Should I be ashamed to say that I like LED's? « Reply #27 on: October 09, 2021, 10:46:53 AM » Author: Mandolin Girl
I'll never like the L*D street lights, apart from the fact they were forced on us with no consultation, I just can't see properly because of the colour temperature used  :-[.
They have not considered that people, like me, who suffer from night blindness are really affected by it.  :curse: >:(
Lightingguy1994
Re: Should I be ashamed to say that I like LED's? « Reply #28 on: October 09, 2021, 01:13:53 PM » Author: Lightingguy1994
LEDs for the most part do not interest me, except for RGB ones. When it comes to fixtures I support LED fixtures that are serviceable. If it takes standard screw base LEDs and doesn't need to be thrown away at EOL its all good with me.
Re: Should I be ashamed to say that I like LED's? « Reply #29 on: October 09, 2021, 02:12:13 PM » Author: wide-lite 1000
My integrated LED failures in my front porch lights did irritate me ! The first one died a little over a year after installing it . When I went to get a replacement , the new ones looked NOTHING like the old . The old looked like MR-16 spot lamps in gimbal trim whereas the new were just a round panel in a totally different design gimbal trim .
