Author Topic: ge to close canadian lamp plant  (Read 2615 times)
Silverliner
Rare white reflector
ge to close canadian lamp plant « on: August 07, 2009, 03:42:33 AM » Author: Silverliner
click here. pretty sad. ge also plans to close the last us household bulb plant in winchester, va.
Member of L-G since 2005.
Electrician.
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Re: ge to close canadian lamp plant « Reply #1 on: August 10, 2009, 05:04:20 PM » Author: Foxtronix
Really sad indeed. I already miss the canadian Soft White etch. It's past now  :'(
KEDER
Re: ge to close canadian lamp plant « Reply #2 on: August 10, 2009, 09:26:20 PM » Author: KEDER
Hmm, they wil just go tomore efficent incandescents. but i will miss the old lamp.
« Last Edit: August 14, 2009, 05:01:28 PM by !KEDER » Logged
Mr. Big
Re: ge to close canadian lamp plant « Reply #3 on: August 13, 2009, 10:57:37 PM » Author: Mr. Big
I prefer an incandescent over a CFL, but if it's not a China CFL, and is not a spiral, I'll use it! The Hungary CFL I got the other day has a real simple ballast! a spiral which is essentially the same, has a complicated ballast! when it could be simple!
Re: ge to close canadian lamp plant « Reply #4 on: August 17, 2009, 05:00:25 PM » Author: Medved
Ballast might be or simple topology, but very sensitive to component parameters, or more complex and much less sensitive and with decent protection. The consequence is, the first one likely over- or under-power the lamp (with consequence on it's life and/or performance) and fail catastrophically (components burn out at lamp EOL), so the fuse is the only component avoiding smoke and/or fire issues.
If there are EOL protection features (so the fuse is only the second-level protection), it always yield to more complex ballast.
But not valid for "more complex" => "better quality" reasonning...
