Author Topic: Ballast codes of MHs, HPSs, LPSs. and Mercury.  (Read 22792 times)
FGS
Rory Mercury!
Ballast codes of MHs, HPSs, LPSs. and Mercury. « on: October 11, 2006, 01:49:50 PM » Author: FGS
Where i can find a list saying what watt goes with what ANSI code of the ballast and what type goes where. Ex- 150w HPS goes in S55 Ballast.
« Last Edit: November 29, 2006, 02:46:44 PM by Jace the TudorMan! » Logged
TudorWhiz
Re: Ballast codes of MHs, HPSs, LPSs. and Mercury. « Reply #1 on: November 30, 2006, 12:08:46 AM » Author: TudorWhiz
I am also interested......I am not sure what codes...can anyone help with the codes? Thanks!
AE125Series
Re: Ballast codes of MHs, HPSs, LPSs. and Mercury. « Reply #2 on: November 30, 2006, 10:26:33 AM » Author: AE125Series
The codes for these lights are as follows:
Mercury Vapor:
H38 100 watt
H39 175 watt
H37 250 watt
H33 400 watt
H36 1000 watt
Metal Halide:
M57 175 watt
M58 250 watt
M59 400 watt
M47 1000 watt
High Pressure Sodium:
S68 50 watt
S62 70 watt
S54 100 watt
S55 150 watt
S66 200 watt
S50 250 watt
S51 400 watt
S52 1000 watt
lightman64
Re: Ballast codes of MHs, HPSs, LPSs. and Mercury. « Reply #3 on: June 16, 2009, 05:18:09 PM » Author: lightman64
What is S76 for HPS?
FGS
Rory Mercury!
Re: Ballast codes of MHs, HPSs, LPSs. and Mercury. « Reply #4 on: June 16, 2009, 06:11:42 PM » Author: FGS
It's 35w. The smallest HPS in production unless they decided to make smaller ones.
Finally completed a list of the ANSI ballast codes:
Mercury Vapor
40w    – H45
50w    – H46
75/80w    – H43
100w    – H38
100/125w    – H44
175w    – H39
250w    – H37
400w    – H33
700w    – H35
1000w    – H34
1000w    – H36
Metal Halide (Red's Probe Start, Rest's Pulse Start)
20w    – M175
22w    – M130
35/39w    – M130
50w    – M110
70w    – M98
100w    – M90
150w    – M102
175w    – M57
175w    – M152
200w    – M136
250w    – M58
250w    – M153
320w    – M154
350w    – M131
360w    – M165
400w    – M59
400w    – M155
450w    – M144
750w    – M149
875w    – M166
1000w    – M47
1000w    – M141
1500w    – M48
1650w    – M112
Double Ended Metal Halide
70w    – M85
100w    – M91
150w    – M81
250w    – M80
1500w    – M133
2000w    – M134
Low Pressure Sodium Vapor
18w    – L69
35w    – L70
55w    – L71
90w    – L72
135w    – L73
180w    – L74
High Pressure Sodium Vapor
35w    – S76
50w    – S68
70w    – S62
100w    – S54
150w    – S55 55v
150w    – S56 100v
200w    – S66
250w    – S50
310w    – S67
400w    – S51
430w    – S145
600w    – S106
750w    – S111
1000w    – S52
« Last Edit: June 16, 2009, 06:18:55 PM by FGS » Logged
tmcdllr
Re: Ballast codes of MHs, HPSs, LPSs. and Mercury. « Reply #5 on: July 21, 2012, 07:35:24 AM » Author: tmcdllr
What is M107?
Nothing like the beautiful cool white light of a coated Mercury Vapor lamp and the soothing hum of it's magnetic ballast.
Re: Ballast codes of MHs, HPSs, LPSs. and Mercury. « Reply #6 on: July 21, 2012, 04:44:24 PM » Author: Ash
Which of them are compatible between different ballasts/lamps ? Eg. which wattages of mercury lamp work ok on the same power MH ballast, MH lamp on HPS ballast etc
Brisluminous
Re: Ballast codes of MHs, HPSs, LPSs. and Mercury. « Reply #7 on: July 23, 2012, 06:43:10 AM » Author: Brisluminous
Thanks this is great information. :)
lights*plus
George Liv Photo
Re: Ballast codes of MHs, HPSs, LPSs. and Mercury. « Reply #8 on: November 23, 2016, 11:25:35 PM » Author: lights*plus
Hum, odd I can't find S167. I have S104 and S105 for 50w & 100w SDW-T white SON lamps, respectively.
What is S167? White Sodium or CMH? I came across this SDW-TG-100W lamp which needs S167.
Re: Ballast codes of MHs, HPSs, LPSs. and Mercury. « Reply #9 on: November 24, 2016, 04:45:14 AM » Author: dor123
Searching "ANSI ballast code" in Google:
First result: http://www.kolmart.com/HID-ANSI-Code-Guide_b_3.html
lights*plus
George Liv Photo
Re: Ballast codes of MHs, HPSs, LPSs. and Mercury. « Reply #10 on: November 24, 2016, 04:28:36 PM » Author: lights*plus
S167 is not included. Our table here is superior, in that HQI lamps have their sperate section and probe vs pulse are highlighted better. When I find the C codes I'll include here.
Re: Ballast codes of MHs, HPSs, LPSs. and Mercury. « Reply #11 on: December 01, 2019, 04:15:37 PM » Author: Mandolin Girl
I wish that it was easy as this to get the correct ballasts for lamps here.
Re: Ballast codes of MHs, HPSs, LPSs. and Mercury. « Reply #12 on: November 27, 2020, 06:52:10 PM » Author: WorldwideHIDCollectorUSA
Here is my revised version of the list of the ANSI ballast codes for American HID lamps along with their associated arc voltages and currents:
Medium/High Pressure Mercury Vapor
40w    – H45 90V 0.53A
50w    – H46 96V 0.6A
75w    – H43 130V 0.66A
80w         – H95 115V 0.8A
100w    – H38/H44/H4 130V 0.85A
125w       – H42 125V 1.15A
175w    – H39/H22 130V 1.5A
250w    – H37/H5 130V 2.1A
400w    – H33/H25/H1 135V 3.2A
425w       – H40/H17 265V 1.7A
700w    – H35/H18 265V 2.8A
1000w    – H34/H12 135V 8.0A
1000w    – H36/H15 265V 4.0A
20w    – M156 94V 0.215A
22w    – M175 100V 0.22A
35/39w    – M130 85V 0.53A
50w    – M110/M148 85V 0.66A
70w    – M98/M143/M139 90V 0.88A
100w    – M90/M140 100V 1.2A
125w    – M150 125V 1.15A
150w    – M102/M142 100V 1.8A
175w    – M57 (M107 for 150w energy saving lamps) 130V 1.5A
175w    – M137/M152 130V 1.5A
200w    – M136 130V 1.6A
250w    – M58 130V 2.1A
250w    – M138/M153 130V 2.1A
300w.       – M151 130V 2.5A
320w    – M132/M154 135V 2.6A
350w    – M131 135V 2.8A
400w    – M59 (M165 for 360w energy saving lamps) 135V 3.2A
400w    – M135/M155 135V 3.2A
450w    – M144 135V 4.0A
750w    – M149 200V 4.0A
875w    – M166 ???
1000w    – M47 265V 4.0A
1000w    – M141 265V 4.0A
1500w    – M48 265V 6.2A
1650w    – M112 270V 6.6A
2000w     – M134 265V 9.2A
70w    – M85 90V 1.0A
100w    – M91 100V 1.2A
150w    – M81 100V 1.8A
250w    – M80 100V 3.0A
1500w    – M133 ???
Low Pressure Sodium Vapor (SOX only)
18w    – L69 57V 0.35A
35w    – L70 70V 0.6A
55w    – L71 100V 0.6A
90w    – L72 112V 0.95A
135w    – L73 165V 0.95A
180w    – L74 245V 0.95A
35w    – S76 52V 0.83A
50w    – S68 52V 1.18A
70w    – S62 52V 1.6A
100w    – S54 55V 2.1A
150w    – S55 55V 3.2A
150w    – S56 100V 1.8A
200w    – S66 100V 2.4A
250w    – S50 100V 3.0A
310w    – S67 100V 3.6A
400w    – S51 100V 4.5A
430w    – S145 100V ??A
600w    – S106 110V 6.2A
750w    – S111 120V 7.0A
1000w    – S52 250V 4.7A
Can someone help me fill in the blanks for the missing lamp arc drops and currents and correct the incorrect lamp voltages and currents?
« Last Edit: January 27, 2024, 01:05:00 PM by WorldwideHIDCollectorUSA » Logged
Re: Ballast codes of MHs, HPSs, LPSs. and Mercury. « Reply #13 on: November 27, 2020, 06:54:13 PM » Author: WorldwideHIDCollectorUSA
In European countries, lamp arc voltages and lamp currents would be memorized in order to match the lamps with their correct ballasts?
lights*plus
George Liv Photo
Re: Ballast codes of MHs, HPSs, LPSs. and Mercury. « Reply #14 on: November 27, 2020, 07:57:13 PM » Author: lights*plus
Memorizing lamp voltages and currents would be difficult for anyone, so I'm sure Europeans rely on the etch or packaging sold with the lamp.
