Author Topic: Mercury Vapor lamps and cold weather  (Read 2765 times)
lightman64
Mercury Vapor lamps and cold weather « on: July 25, 2009, 11:05:00 AM » Author: lightman64
Why do MV lamps have trouble starting in cold weather? And when they do start, they don't get as bright as normal.
Re: Mercury Vapor lamps and cold weather « Reply #1 on: July 26, 2009, 12:43:49 AM » Author: icefoglights
I'm not sure.  I know from first hand experience that it can vary from manufacturer to manufacturer.  I have an older GE and GTE Sylvania at home that would start like champs even at -40° but a Philips Lifeguard, Regent and Caster bulbs that refuse to start at -15°F.  However, once lit they all seemed to reach full brightness with no problems.
bluelights
Re: Mercury Vapor lamps and cold weather « Reply #2 on: July 26, 2009, 08:05:19 AM » Author: bluelights
I thought the light output of high-pressure lamps is not dependent on ambient temperature (within "normal" limits) because the arctube burns so hot that it's not influenced by (in comparison) little fluctuations of ambient temperature...
Save the mercury lamp
Re: Mercury Vapor lamps and cold weather « Reply #3 on: July 26, 2009, 01:08:38 PM » Author: Medved
@bluelight: The light output does not, but the required starting voltage does depend and a lot. And if the temperature drop so, the starting voltage is higher then the ballast deliver (the mains voltage in 230V areas), it does not ignite.
