Author Topic: Non-pulse-start Metal Halide Bulb. (400w)  (Read 2184 times)
KEDER
Non-pulse-start Metal Halide Bulb. (400w) « on: July 16, 2009, 11:08:01 PM » Author: KEDER
Hmm, will it work on a 400w MV ballast? Brian said nop, but he migth of thought it was pulse start. will a MH bulb work with MV? ill takwe a pic of the bulb. its 400w./
says it works only with ANSI M59E ballasts.
« Last Edit: July 16, 2009, 11:12:06 PM by !KEDER » Logged
Re: Non-pulse-start Metal Halide Bulb. (400w) « Reply #1 on: July 17, 2009, 01:41:52 AM » Author: Medved
MH require higher OCV then MV, so it might not ignite. You might overcome it by adding low voltage pulse ignitor (<1kV; series combination of ~150W 240V incandescent with "higher power" fluorescent starter might work as parallel ignitor).
don93s
Re: Non-pulse-start Metal Halide Bulb. (400w) « Reply #2 on: August 16, 2009, 01:37:43 PM » Author: don93s
Yeah, the lower OCV will create starting problems. Also, it's been said that the MV ballasts have a more distorted current waveform and could shorten the life of certain MH's.
