Author Topic: What causes MH lamp to cycle somtimes at EOL?  (Read 1254 times)
What causes MH lamp to cycle somtimes at EOL? « on: May 20, 2021, 09:53:03 AM » Author: dor123
As the operating voltage of MH lamps, remains constant similar to MV lamps, compared to the voltage rising of HPS lamps, what can cause MH lamps to cycle sometimes at EOL?
Re: What causes MH lamp to cycle somtimes at EOL? « Reply #1 on: May 20, 2021, 02:53:36 PM » Author: James
MH lamps can cycle by the same process as HPS : voltage rise during life.  Although the arc voltage does not rise so quickly as HPS, there is still some increase in life.  There are two mechanisms.  As the arc tube blackens during life, this causes its temperature to increase and that causes an increase in voltage.  Similarly the electrodes burn back slightly and the increased arc gap increases the voltage - that effect is more significant with short arc and low power types.
But another mechanism is often more severe.  During life some of the metals react with the quartz and are lost, leading to an increase in free iodine within the arc tube.  If the lamp has an excellent hydrogen getter in the outer jacket this is no problem.  But if not, or if the getter has become saturated over time, the tiny traces of hydrogen will diffuse into the arc tube and react with the iodine to form Hydrogen Iodide.  This compound is extremely electronegative and increases the reignition peaks of the voltage waveform.  As the arc tube runs up the HI vapour pressure begins to increase, and if sufficient is present it can steals enough electrons from the arc to cause the reignition peaks to rise to the level that the arc will extinguish.
« Last Edit: May 20, 2021, 02:58:40 PM by James » Logged
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Re: What causes MH lamp to cycle somtimes at EOL? « Reply #2 on: May 21, 2021, 09:54:46 PM » Author: Foxtronix
You're a walking encyclopedia.  ;D :bulbman:
How on earth do you get all that information? General physics and chemistry applied to lighting? Or engineering documentation? Both maybe?  8)
Re: What causes MH lamp to cycle somtimes at EOL? « Reply #3 on: May 22, 2021, 12:16:42 PM » Author: James
I gained the knowledge from other colleagues at work, and by developing my own metal halide lamps and following up why they fail on the lifetest racks - and then how to solve those problems so as to develop longer-lived lamps :-)
