Author Topic: SOX lamps having trouble starting with HV ignitors.  (Read 1387 times)
SOX lamps having trouble starting with HV ignitors. « on: May 10, 2021, 04:48:00 AM » Author: WorldwideHIDCollectorUSA
After doing experiments with trying to ignite SOX low pressure sodium lamps on high voltage high pressure sodium ignitors and pulse start metal halide ignitors, I have noticed that despite sending a few kilovolts through the discharge, I have noticed that the lamps had trouble starting. Strangely, SOX ignitors tend to have a lower ignition pulse voltage compared to high pressure sodium ignitors and pulse start metal halide ignitors yet, the SOX lamps start more reliably with the ignition pulses of SOX ignitors. Can someone help explain this to me further?
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Re: SOX lamps having trouble starting with HV ignitors. « Reply #1 on: May 10, 2021, 05:56:16 PM » Author: Foxtronix
(I was about to post my reply, but apparently the whole thread's been purged, double-checked just in time!)
I expected this setup to work. Unless the high voltage pulses are strong enough for an arc to jump outside the arctube somewhere. But aren't the outer bulbs of these just under vacuum?
Keep in mind though that LPS lamps' atmosphere is mostly neon, unlike other lamps' usual argon (not considering the evaporated metal at working temps). Maybe it requires a different kind of high voltage pulse? Like, lower peak value but longer duration?
I dunno, just speculating here  :mrg:
Lightingguy1994
Re: SOX lamps having trouble starting with HV ignitors. « Reply #2 on: May 10, 2021, 06:08:33 PM » Author: Lightingguy1994
Received a report from someone on this thread.. Wheres the problem? Or was the feature misused?
Foxtronix
Re: SOX lamps having trouble starting with HV ignitors. « Reply #3 on: May 10, 2021, 07:51:25 PM » Author: Foxtronix
I was *almost* there. Everything but the original post has been deleted while I was writing my reply. Without going into details, things got a bit tense between some people. But I've seen worse.
Re: SOX lamps having trouble starting with HV ignitors. « Reply #4 on: May 11, 2021, 02:55:54 AM » Author: Medved
The problem is, the SOX (and other cold starting low pressure lamps like slimlines or so) need not only to break down the gas, but also support quite significant current when the electrodes are still cold, so have high cathode drop voltage, in order to warm them up and so turn the discharge into a proper hot electrode arc.
Better to say all lamps need this, but the high pressure ones (HPS, MH,...) have very low voltage drop over the rest of the discharge when cold, so the normal operating OCV is enough to support such current, so the ignitor is required only for the initial gas breakdown.
The low pressure lamps (SOX, slimlines,...) operate at low temperatures, so the pressure so voltage drop across the rest of the arc is close to the normal operating drop. Wen the cold cathode drop adds on top of that normal voltage drop, it becomes too high for the lower OCV ballasts to support the current so the lamp does not start.
To address this, in the past a ballast with just high enough OCV to overcome both the cathode drop and the anode column fall (with sufficient margin to allow reliable reignition after zero cross) was used. But high OCV means the ballast needs a lot of turns on the secondary, so a long wire, so yields high losses and very heavy and expensive ballast. But before the solid state electronic became usable, it was the only way to feed such lamps, so it was accepted.
Now the SOX ignitors use a different approach: When they sense too high voltage drop (aka arc not there or with too high voltage to be supported by the ballast alone), it generates HF higher voltage, some 10kHz, superimposed on the ballast OCV. That rises the peak voltage to the rated 750V or so (sufficient for the gas breakdown), but mainly it is able to feed quite significant current at that voltage (it is an HF AC generator, not just pulser), so feed enough power at that higher voltage to allow the electrodes to warm up.
With HPS/MH ignitors you may get higher peak voltage, but with very low power. And it is the power at the elevated (not necessarily high) voltage, what is missing for successful SOX or slimline fluorescent start.
To be clear, we are talking about half second till few seconds after first gas breakdown, so a short time, just to allow the electrode filaments to warm up, but when such feed is not provided, the lamp can not pass the warmup state. And the only thing you will get is the HV ignitor causing cold electrode sputtering.
