Author Topic: Full spectrum F40T12 high CRI over 95 - lamps?  (Read 1970 times)
AZTECH
Full spectrum F40T12 high CRI over 95 - lamps? « on: May 08, 2021, 07:10:20 PM » Author: AZTECH
Is there any companies still making F40T12 lamps that has full spectrum and well over 95 CRI?  Last time I know it was Verilux they did claimed 96 CRI but seem they no longer made these T12 lamps
The second best maybe GE Chorma 50 & 75 but 92 CRI?  No longer made over 95 CRI?
I was doing remodel one of my mobile home and it has massive 8 - T12 lamps of 5 fixtures being installing. 4 switches that control pair 2 lamps. Nice of wide choice of color fluorescents for mood.
Re: Full spectrum F40T12 high CRI over 95 - lamps? « Reply #1 on: May 08, 2021, 10:27:13 PM » Author: dor123
There is no such a thing "Full spectrum lamp".
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: Full spectrum F40T12 high CRI over 95 - lamps? « Reply #2 on: May 08, 2021, 11:43:08 PM » Author: Binarix128
The only lamps that are "full spectrum" are incandescents and halogens. The term "full spectrum" is also used in grow lamps.
Re: Full spectrum F40T12 high CRI over 95 - lamps? « Reply #3 on: May 09, 2021, 12:05:09 AM » Author: joseph_125
I did a rough look at the Big Three and it seems like sadly the highest CRI for F40T12 tops out at 90 for currently listed lamps.
If you're willing to convert to F32T8, Philips still lists the F32T8/TL950 which is rated at 98 CRI. I'm not sure if it's worth it though but you can get old stock magnetic rapid start ballasts so they behave more like T12s on a rapid start ballast.
I would suggest to go NOS but it's gonna be hard to find something like that.
AZTECH
Re: Full spectrum F40T12 high CRI over 95 - lamps? « Reply #4 on: May 09, 2021, 12:46:23 AM » Author: AZTECH
Almost all T12 ballast are in excellent condition and I don't think they will burn out anytime soon but if it does I could upgrade to F32T8 gear but doing upgrade it all it probably costly and waste lot of T12 ballast. :wndr:
Re: Full spectrum F40T12 high CRI over 95 - lamps? « Reply #5 on: May 09, 2021, 04:24:40 AM » Author: dor123
Even incandescents and halogens aren't "Full spectrum". This term is a fictional term that don't even exists in physics and chemistry fields.
AZTECH
Re: Full spectrum F40T12 high CRI over 95 - lamps? « Reply #6 on: May 09, 2021, 08:32:40 PM » Author: AZTECH
I only orginal asking what's best quality highest CRI F40T12 lamps available for replacement and not asking into the science political stuff.
I do understand that wavelength comparing cannot exactly same the lamp between fire ball sun.
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Re: Full spectrum F40T12 high CRI over 95 - lamps? « Reply #7 on: May 09, 2021, 09:21:15 PM » Author: Foxtronix
Is the daylight deluxe tube (F40/DX) even still made today? I think its CRI is around 92 but that's probably as high as it'll ever get for 40W T12s. Maybe those newer phosphors that were developed as replacement for the halophosphate cool white and warm white do about as good CRI wise.
Re: Full spectrum F40T12 high CRI over 95 - lamps? « Reply #8 on: May 10, 2021, 09:20:46 PM » Author: funkybulb
There some Kinoflo Movie lamps out there with high CRI
Lamps in 3209K and 5500K
AZTECH
Re: Full spectrum F40T12 high CRI over 95 - lamps? « Reply #9 on: May 10, 2021, 10:04:07 PM » Author: AZTECH
It is over 95 CRI? It still in production?
Re: Full spectrum F40T12 high CRI over 95 - lamps? « Reply #10 on: May 10, 2021, 10:59:24 PM » Author: funkybulb
 Yes they are 95 CRI
   I have 8 footer in my pop pack as it only source of 8 foot bipin  tube for my pop pack too.
