Author Topic: Date Code Help  (Read 2127 times)
lightingcollector84
Date Code Help « on: July 06, 2009, 06:15:00 PM » Author: lightingcollector84
Ok, I got a couple of failed lamps from the library today and I need help with the date code.  The first lamp is a Philips 70w MH.  The code is M2-1.  The second lamp is a Sylvania 100w MH and the code is M90 R.
Thanks for any help you can provide
FGS
Rory Mercury!
Re: Date Code Help « Reply #1 on: July 06, 2009, 06:43:53 PM » Author: FGS
Philips - Made in December 2002.
Sylvania - M90 is the ballast code. Try looking at the screw base.
lightingcollector84
Re: Date Code Help « Reply #2 on: July 06, 2009, 07:10:08 PM » Author: lightingcollector84
Thanks for your reply to the Philips. I cannot see any other code on the Sylvania lamp, but near the base has turned that metallic silver color.  The etch on the lamp looks new, so I don't think this lamp is that old.
