April 26, 2025, 09:18:53 PM
Modern
Metal halide ballast options for mercury 50W?
Topic: Metal halide ballast options for mercury 50W? (Read 1114 times)
OgreVorbis
« on: April 16, 2021, 03:15:14 AM »
OgreVorbis
For a 50W mercury vapor, should I use a 50W metal halide ballast or would 39W be better?
I figure I'd have to go with a transformer ballast so I could remove the igniter. Is it obvious how to wire it up once the igniter is removed?
Has anyone been able to remove the igniter in a metal halide electronic ballast cause they are much cheaper and I like how small they are.
Re: Metal halide ballast options for mercury 50W?
« Reply #1 on: April 16, 2021, 09:03:51 AM »
Author: sox35
Personally the best option for me is to get a 50W MV ballast...
« Reply #2 on: April 16, 2021, 10:52:45 AM »
Author: sox35
Always best to use the correct gear if at all possible. Sometimes, certain ballasts are virtually impossible to obtain, such as for the 200W SLI/H lamp, but if you can get the correct one, do
f36t8
« Reply #3 on: April 16, 2021, 11:14:52 AM »
f36t8
I think the metal halide 50 W lamps have a somewhat lower arc voltage but higher current than 50 W mercury lamps. Since the ballast mainly determines the current, using an MH ballast for 50 W will cause some overdrive. On the other hand, a 39 W metal halide ballast will cause some underdrive. Between the two, I would pick the lower one since I think it is probably less harmful for the lamp.
If you are in "230 V-land", you can parallel a 40 W fluorescent choke with a 7/9/11 W PL-S choke. I have operated 50 W MVs like that and the final current ended up at the specification (0,61 A in my notes).
