Author Topic: Where can I find start capacitors for ceiling fans?  (Read 2900 times)
thelightingman
All lighting except LED rules!
Where can I find start capacitors for ceiling fans? « on: April 15, 2021, 09:10:24 PM » Author: thelightingman
I need a start capacitor for a ceiling fan I found new in the box in my collapsing shed. I can get it to go if I spin it by hand but it won't go on its own. The capacitor is 4uf.
« Last Edit: April 17, 2021, 04:18:39 PM by thelightingman » Logged
I think HPS, MV, and MH rule! :mv: :mvc: :hps: :emh: Ban LED instead! :eoled:
Re: Where can I find start capacitors for ceiling fans? « Reply #1 on: April 16, 2021, 02:54:36 AM » Author: Medved
I guess in a fan it would be a motor run capacitor (connected all the time), not just start (disconnected once the motor starts).
Look for electronic component distributors like RS or Newark or so, "motor run capacitor 4uF xxxV"
Bulbman256
Mad Max
Bulbman256
Re: Where can I find start capacitors for ceiling fans? « Reply #2 on: April 16, 2021, 11:24:38 AM » Author: Bulbman256
I think I might have a 4uf in a bin of parts I have from some old fans, I can check them out when I get home for you. :D
thelightingman
Re: Where can I find start capacitors for ceiling fans? « Reply #3 on: April 16, 2021, 01:34:13 PM » Author: thelightingman
Thanks! It has a red wire and a white wire. That's the one I need. I will get a picture soon for you. It's from a 1998 Harbor Breeze Armitage ceiling fan I found as new old stock in my shed.
« Last Edit: April 16, 2021, 01:45:01 PM by thelightingman » Logged
thelightingman
Re: Where can I find start capacitors for ceiling fans? « Reply #4 on: April 16, 2021, 01:41:00 PM » Author: thelightingman
Here is the capacitor
thelightingman
Re: Where can I find start capacitors for ceiling fans? « Reply #5 on: April 16, 2021, 04:33:54 PM » Author: thelightingman
Whenever you find it, can you send me a picture?
Bulbman256
Mad Max
Bulbman256
Re: Where can I find start capacitors for ceiling fans? « Reply #6 on: April 16, 2021, 04:54:22 PM » Author: Bulbman256
Dug through my parts and found a similar 4.75 uf one, seems to be the same size and it measured on my meter as 4.6uf. I have two of these guys. :)
thelightingman
Re: Where can I find start capacitors for ceiling fans? « Reply #7 on: April 16, 2021, 05:38:16 PM » Author: thelightingman
Thanks! Can I have a picture of them? Luckily, the motor in this fan is designed for up to a 5uf cap.
« Last Edit: April 16, 2021, 05:43:20 PM by thelightingman » Logged
thelightingman
Re: Where can I find start capacitors for ceiling fans? « Reply #8 on: April 16, 2021, 09:44:53 PM » Author: thelightingman
I have a photo of the whole fan and the owner's manual in my off topic section.
Bulbman256
Mad Max
Bulbman256
Re: Where can I find start capacitors for ceiling fans? « Reply #9 on: April 16, 2021, 10:36:48 PM » Author: Bulbman256
Pm sent. :bulbman:
thelightingman
Re: Where can I find start capacitors for ceiling fans? « Reply #10 on: April 16, 2021, 10:37:37 PM » Author: thelightingman
Pm sent. :bulbman:
I just got the PM.
