Author Topic: 4 pin F90T17 starters?  (Read 877 times)
Bulbman256
Mad Max
Bulbman256
4 pin F90T17 starters? « on: April 04, 2021, 05:01:15 PM » Author: Bulbman256
Hey all,
I heard about 4 pin F90T17 starters and wonder what is the point and how they are wired. ??? Any info is appreciated.
desktoptrashcan
theroadrunner556
Re: 4 pin F90T17 starters? « Reply #1 on: April 04, 2021, 05:14:19 PM » Author: desktoptrashcan
They were originally thermal starters with the heating coil in series with the bulb and the bimetallic contacts wired where a typical 2 pin glowbottle starter would be wired. The thermal starters were desgined to easily start the F90T17 tubes, even in cold conditions. Later, glowbottle retrofits were made (some of which I own). These simply have a brass shorting strip wired in series with the bulb, and the glowbottle part wired where a 2 pin starter would normally be wired.
Hope this helps.  :)  :eolfl:
Bulbman256
Mad Max
Bulbman256
Re: 4 pin F90T17 starters? « Reply #2 on: April 04, 2021, 05:33:01 PM » Author: Bulbman256
Oh okay, Thank you! ;D Wonder why the coil wasn't just a seperate part instead of being with the starter. :wndr:
desktoptrashcan
theroadrunner556
Re: 4 pin F90T17 starters? « Reply #3 on: April 04, 2021, 05:36:08 PM » Author: desktoptrashcan
Probably cheaper (and easier) to manufacture it that way.
« Last Edit: April 04, 2021, 05:39:31 PM by desktoptrashcan » Logged
Bulbman256
Mad Max
Bulbman256
Re: 4 pin F90T17 starters? « Reply #4 on: April 04, 2021, 05:37:32 PM » Author: Bulbman256
But you would have to change it out every time you put in a new starter, maybe it wore out somehow. :P
desktoptrashcan
theroadrunner556
Re: 4 pin F90T17 starters? « Reply #5 on: April 04, 2021, 05:39:09 PM » Author: desktoptrashcan
I suspect that compatibility with 4 and 2 pin glowbottle starters may have also been a factor once those became the industry standard.  :a_starter:
