Author Topic: Self Ballasted.  (Read 2174 times)
Attfreakk
Self Ballasted. « on: March 28, 2021, 02:53:01 PM » Author: Attfreakk
What is the reason for self ballasted mercury lamps if they have the same efficiency and life of an incandescent?
Krep
Re: Self Ballasted. « Reply #1 on: March 28, 2021, 05:16:37 PM » Author: Krep
Because they are cheap and does'nt require ballast for operation.
Joe Maurath, Jr.
Re: Self Ballasted. « Reply #2 on: March 28, 2021, 07:48:27 PM » Author: Joe Maurath, Jr.
The published advantages of self-ballasted MV lamps was longer life (around 10,000 hours) or about 7-10 times longer than the typical incandescents they were designed to replace with somewhat improved efficacy. The biggest drawback with SBMV lamps has been that they always have been quite expensive. :mvc:
AZTECH
Re: Self Ballasted. « Reply #3 on: March 29, 2021, 01:07:16 AM » Author: AZTECH
I am wondering if it's reliable and it does last long time?
Rich, Coaster junkie!
Re: Self Ballasted. « Reply #4 on: March 29, 2021, 06:21:02 AM » Author: AngryHorse
They were also a brightness upgrade back in their day, if you had a workshop lit with 500 watt clear GLS @8200 lumens, you could direct fit 500 watt MBTF, and get 13,000 lumens for the same load
Current: UK 230V, 50Hz
Power provider: e.on energy
Welcome to OBLIVION
Re: Self Ballasted. « Reply #5 on: March 29, 2021, 12:34:11 PM » Author: sox35
One of the main reasons for using them was if the fixtures were in difficult to reach places where it would be costly and time consuming to re-lamp. Also they could directly replace incandescent bulbs.
