desktoptrashcan
There are always exceptions to any rule. But they are rare, and when such substitutions are made, all efforts must be taken to ensure no-one is at any risk. If there is the slightest doubt, don't do it, even if it means not lighting that rare lamp. In any case, you wouldn't want to destroy a lamp you'd waited years to acquire and may never find again, would you..?
By suitable, I mean the replacement still allows the bulb to run at the correct voltage and current (or something very close to it). That being said, you do make a good point on not destroying a rare bulb by running it on gear that horrendously overdrives it.
Desultory13
I agree, just do your research, ask around, someone has been there before you.
Desultory13
Yeah that's about all there is to it. Hands down no BS. Without the proper gear it just don't get lit. There's just no excuse for destroying that rare one of a kind lamp simply because you saw it done elsewhere.
Joe Maurath, Jr.
Transgender, Avid About Street Lamps, Insulators.
"A secret to happiness is letting every situation be what it is, instead of what you think it should be, and then making the best of it."
Please refer to www.insulators.info where I periodically post many images of lights and insulators in the group's Picture Poster Gallery. Thank you.
desktoptrashcan
desktoptrashcan
Joe Maurath, Jr.
I've always at least tried it. With incandescents it's relatively easy if you have a Variac. I just wind up the voltage very, very slowly until I see the filament just start to glow. If it seems ok, I'll increase voltage to about half way and then probably leave it at that if it's a very rare lamp like Barnaby. He's a special case though, so he won't be lit again, we've got a display case on order and he'll go in that when it gets here.
But if I've got the gear, I'll at least attempt to light it, whatever it is. To me, there's not a lot of point in having a lamp if you can't at least do that. I've always believed lamps were meant to be lit
Another inherent danger facing rare lamps (and any others for that matter that we have) is handling them. That is exactly how they can easily break or get damaged. And as I look back, I have lost a few medium rare lamps on account of them slipping out of my hands, rolling off a table, hitting another bulb in a storage carton, etc, etc. When this happens the disaster seems to be over before we know what has happened. So, I AVOID moving my good and respected lamps around because of prior misfortunes. Even being as very careful (as I am) these things can and still can happen. Most of my lamps are displayed on wall shelves and I leave them right there, period.
Same here. I always use cotton gloves when handling any lamp, even if they don't strictly need it. It's for two reasons; one I don't like fingerprints on glass and two it's just in case a lamp does need special handling and I forget. If I always do things the same way, then it's less likely I'll make a mistake. I treat every lamp as rare, even if it's a common household incandescent. We're still in the process of fitting shelves and things, it's a work in progress. We don't have a lot of space here, so it's difficult
Joe Maurath, Jr.
« Last Edit: March 21, 2021, 08:51:37 PM by sox35 »
Joe Maurath, Jr.
I use this to check discharge lamps, all it really does is check vacuum, but it does light up the arc tube quite nicely on most lamps.
I have never seen one of those, what a cool device! Would make for a dandy Holiday gift too for HID lovers like myself
I got it on UK eBay quite cheap as it was second hand, but try here. Edit - here is the manufacturer's site, quite a good price there, too.
« Last Edit: March 21, 2021, 09:08:11 PM by sox35 »
Joe Maurath, Jr.
