Author Topic: Igniting North American 175w - 400w probe start MH lamps with a glowstarter  (Read 1111 times)
Igniting North American 175w - 400w probe start MH lamps with a glowstarter « on: March 20, 2021, 11:30:27 PM » Author: WorldwideHIDCollectorUSA
I am wondering if I can reliably ignite North American 175w M57, 250w M58, and 400w M59 probe start metal halide lamps using a glowbottle starter in parallel with the lamp on a ballast with an OCV between 220v and 240v. I am interested in doing such experiments because I like watching preheat fluorescent lights blink to life upon applying power and watching HID lamps warming up to full power. I wonder if I can connect a resistor in series with the glowbottle starter to help limit current to the glowbottle starter and allow it to last its rated life.
Re: Igniting North American 175w - 400w probe start MH lamps with a glowstarter « Reply #1 on: March 21, 2021, 02:45:49 AM » Author: dor123
It is possible. But I'm heard that Na-Sc MH lamps are intended to be work on CWA and not on reactor ballast, since any voltage variation may lead to color change.
Re: Igniting North American 175w - 400w probe start MH lamps with a glowstarter « Reply #2 on: March 21, 2021, 03:18:29 AM » Author: WorldwideHIDCollectorUSA
@dor123, in North America, we do have some CWA mercury vapor ballasts in North America that do have an OCV that is roughly between 220v and 240v. Plus, in addition, there are some 277v reactor/choke ballasts that are intended for sodium scandium probe start and pulse start metal halides too, finally, most low wattage sodium scandium pulse start metal halide lamps in North America that are electrically interchangeable with European high pressure sodium lamps typically use HX ballasts.
