Author Topic: HPS retrofit bulb for 100W mercury ballast?  (Read 8734 times)
UChBXesrxSalDTp79uMtfDvA
Re: HPS retrofit bulb for 100W mercury ballast? « Reply #15 on: January 17, 2025, 03:30:45 PM » Author: WorldwideHIDCollectorUSA
That is quite dangerous, even if the lamp does strike and run up, its voltage is so low that it causes the current to increase significantly.  This leads to overheating of the ballast windings, followed by deterioration of its insulation and eventual failure of the ballast.  Some years ago Philips launched an energy-saving ceramic metal halide lamp to work on mercury 80W and 125W ballasts and they achieved that by reducing the arc voltage from 115V to 105V (lamp type CDO-H).  However even that small decrease started causing massive problems in the field of ballasts burning out, and the lamps were quickly withdrawn from sale.  With a 90V sodium arc tube it would be similarly bad (although current increase is not quite so high because the sodium arc has a very different power factor than mercury or metal halide arcs).
Another factor that I see with high pressure sodium lamps is that the rising voltage during life would allow for the ballast to run cooler.
Re: HPS retrofit bulb for 100W mercury ballast? « Reply #16 on: January 25, 2025, 03:47:06 PM » Author: WorldwideHIDCollectorUSA
Whenever it comes to retrofitting North American 100W H38 mercury vapor fixtures with HX ballasts to a more efficient HID light source, a Japanese metal halide retrofit lamp designed for Japanese 100W mercury vapor ballasts seems to work fine as long as the fixture has the socket oriented either base up or base down.
