Author Topic: Running 310w S67 HPS lamps on 400w M135/M155 PSMH CWA ballasts  (Read 1252 times)
Running 310w S67 HPS lamps on 400w M135/M155 PSMH CWA ballasts « on: March 08, 2021, 10:17:04 PM » Author: WorldwideHIDCollectorUSA
After I have been able to run a North American 310w S67 high pressure sodium lamp on a North American 400w M135/M155 pulse start metal halide CWA ballast, the lamp was able to run at around 125v 3.3a while it is intended for 100v 3.6a operation. I have been told by James that a mercury vapor or metal halide ballast’s temperature does not change if I use a high pressure sodium lamp designed for a slightly lower arc voltage compared to mercury vapor lamps or metal halide lamps that run at the same arc voltage and current as their mercury vapor counterparts. In addition, I have been told by Joe Maurath Jr. that it is safe to underdrive HID lamps on HX or choke ballasts, but not CWA ballasts. Should I be concerned about damaging my 400w M135/M155 pulse start metal halide ballast if it is a CWA ballast?
Re: Running 310w S67 HPS lamps on 400w M135/M155 PSMH CWA ballasts « Reply #1 on: March 09, 2021, 12:17:38 AM » Author: dor123
HPS lamps are characterised by voltage rise during life, and this can cause CWA ballast to allow the lamp to run at dangerously high power loading.
Re: Running 310w S67 HPS lamps on 400w M135/M155 PSMH CWA ballasts « Reply #2 on: March 09, 2021, 12:19:18 AM » Author: WorldwideHIDCollectorUSA
From what I understand, North America does use CWA ballasts for high pressure sodium lamps. I am still wondering if the 400w M135/M155 pulse start metal halide ballast will be damaged by operating the 310w S67 high pressure sodium lamp on it.
« Last Edit: March 09, 2021, 01:37:48 PM by WorldwideHIDCollectorUSA » Logged
lights*plus
George Liv Photo
Re: Running 310w S67 HPS lamps on 400w M135/M155 PSMH CWA ballasts « Reply #3 on: March 30, 2021, 05:00:12 PM » Author: lights*plus
If I had a 310 watt HPS lamp I would buy this cheaply priced module, only to have the correct ballast for these rare lamps:
https://www.ebay.com/itm/284065487133
