Author Topic: PSMH bulb going out after startup then starting again?  (Read 1314 times)
lightinglover8902
GoL UCfoxh9h5FaLg-R04V8WDi3w
PSMH bulb going out after startup then starting again? « on: March 08, 2021, 04:39:06 PM » Author: lightinglover8902
When I was seeing a 100w PSMH lamp in a recessed can light, it started up but then goes out. After a few minutes, it started up. Could this mean that the lamp is heading EOL?
Re: PSMH bulb going out after startup then starting again? « Reply #1 on: March 08, 2021, 09:19:38 PM » Author: wide-lite 1000
Yep .
flyoffacliff
Re: PSMH bulb going out after startup then starting again? « Reply #2 on: March 16, 2021, 11:08:37 PM » Author: flyoffacliff
I have seen MH cycle, but it's usually just HPS for some reason, does anyone know why?
Re: PSMH bulb going out after startup then starting again? « Reply #3 on: March 17, 2021, 02:01:58 AM » Author: dor123
HPS lamp voltage rises during life, while MH lamp voltage remains constant.
Re: PSMH bulb going out after startup then starting again? « Reply #4 on: March 17, 2021, 03:41:19 AM » Author: Medved
This is not always true, it depends on the fill composition and dosing, to what extend the fill components responsible for the arc voltage are operating at unsaturated vs saturated pressure.
Definitely the arctube gets hotter as the lamp ages. If saturated behavior dominates, the lamp then behaves very similar to HPS.
E.g. ceramic operate still quite big liquid salt pool, rhose components for sure operate at saturated vapor (still dunno how far these influence the arc voltage).
