Author Topic: Recommended temperature to heat a ballast to remove tar  (Read 1111 times)
Recommended temperature to heat a ballast to remove tar « on: March 02, 2021, 11:33:05 PM » Author: HomeBrewLamps
I have two AD lite preheat ballasts with rotting cloth wires. And the tar is making it a huge pain in the butt to repair them. What is the recommended temp to heat them up to remove tar while not damaging components?
~Owen
Bulbman256
Mad Max
Bulbman256
Re: Recommended temperature to heat a ballast to remove tar « Reply #1 on: March 03, 2021, 01:16:15 AM » Author: Bulbman256
Frankly im not sure, but i think the reccomended temp is when it starts to melt ;D
Just watch out for those Tar fumes, dont wanna end up like Ralph Wiggum! :mrg: :lol:
Re: Recommended temperature to heat a ballast to remove tar « Reply #2 on: March 03, 2021, 10:22:39 AM » Author: funkybulb
  About 350 F  is the starting point to melt the tar.  Best use a high wattage incandescent and let tar drip out on it own
  Once u expose enough tar.  At that  much trouble u might as well  remove the old pcb cap. And extend the wires externally
To remote mount the cap.
    Ive been making home made preheat ballast to restore lights
 Out of rapid start  ballast.  And using magnet wire from dishwashers.  That been my latest hobby of mind is restorimg
 Old  preheat ballast.
Re: Recommended temperature to heat a ballast to remove tar « Reply #3 on: March 03, 2021, 03:31:20 PM » Author: HomeBrewLamps
What are the capacitor values usually? Also is the value critical? Obviously the voltage should remain the same or higher but does the MFD rating matter?
~Owen
