Author Topic: Is it ok to run a 175 watt mercury vapor bulb on an hps starter?  (Read 5164 times)
thelightingman
All lighting except LED rules!
Re: Is it ok to run a 175 watt mercury vapor bulb on an hps starter? « Reply #15 on: February 27, 2021, 12:35:02 AM » Author: thelightingman
The arc voltage and current of a 175W MV lamp is 130V at 1.5A. The current is too high, and the voltage is too low.
A better ballast substitution would be an M57 metal halide ballast.
Where can I find an M57 ballast? Or an H39 ballast? (the ballast the lamp is designed for)
I think HPS, MV, and MH rule! :mv: :mvc: :hps: :emh: Ban LED instead! :eoled:
Re: Is it ok to run a 175 watt mercury vapor bulb on an hps starter? « Reply #16 on: February 27, 2021, 12:40:59 AM » Author: joseph_125
M57 ballasts you could probably still get from lighting stores or eBay. H39 ballasts you'll have to get NOS from eBay. If you're in the US or Canada you could also try going to your local Habitat Restore and seeing if there's any ballasts or fixtures that can run 175w lamps. 175w MV was a very common wattage so you might be able to get a used fixture there.
thelightingman
Re: Is it ok to run a 175 watt mercury vapor bulb on an hps starter? « Reply #17 on: February 27, 2021, 12:48:09 AM » Author: thelightingman
I once saw a 175 watt light at a Restore but I went back the next day to get it and it was gone because where I live, they are super popular. I plan to check tomorrow to see if I can find one but for now I am temporarily running it on a 250 watt hps ballast (why I originally posted my question) and the ballast it in 1 of 2 street lights I found at the Restore. It works well but when it is at full brightness, it flashes brighter for a few seconds so that's why I am looking for a dedicated fixture for my bulb.
Re: Is it ok to run a 175 watt mercury vapor bulb on an hps starter? « Reply #18 on: February 27, 2021, 07:20:07 AM » Author: sox35
It's never a good idea to run a discharge lamp on the wrong ballast for long. For a quick test you'll probably be ok, but long term, do try and get the right one.
thelightingman
Re: Is it ok to run a 175 watt mercury vapor bulb on an hps starter? « Reply #19 on: February 27, 2021, 10:00:33 AM » Author: thelightingman
That's what I am trying to do.
Joe Maurath, Jr.
Re: Is it ok to run a 175 watt mercury vapor bulb on an hps starter? « Reply #20 on: February 27, 2021, 11:54:13 AM » Author: Joe Maurath, Jr.
I have run MVs underwattage on HX ballasts with no problems. However never operate a MV of another wattage on a CWA ballast because you will soon cook it and the capacitor.
thelightingman
Re: Is it ok to run a 175 watt mercury vapor bulb on an hps starter? « Reply #21 on: February 27, 2021, 12:03:58 PM » Author: thelightingman
I am running mine with a 250 watt hps ballast with capacitor
« Last Edit: February 27, 2021, 12:05:33 PM by thelightingman » Logged
