Author Topic: Why are good quality arms so expensive?  (Read 2092 times)
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: Why are good quality arms so expensive? « Reply #15 on: February 22, 2021, 11:59:46 AM » Author: Binarix128
My mantra in buying most things is to always buy top quality products. Yes you might have to save up before getting them but generally you only need to buy once rather than replacing it after a few years.   :wndr:
In the end you spend more money if you buy the cheaper alternative :bulbman:
It mostly works like that, but not always.
E.g. A very cheap fluorescent fixture with crap tube and aluminum windings, which cost 4 times less than a proper one, but you will end up spending more than if you buy the proper one, because you will need to change it all the time.
Not the case with the arms, as Medved said, for the mass installation it is better to buy proper ones, because they will leave them with no maintenance forever. But we enthusiasts have the luxury of giving maintenance because we don't have much fixtures and all of them are likely to be in the same place, so suddenly a cheap arm from a scrap becomes cheaper.
Another option would be to buy a steel pipe of the same quality as the arm but for 10 bucks and get 3 arms from it, then you bend them and they will last as good or better than the commercial counterpart, for way cheaper, but then again that's something exclusive to us enthusiasts who "operate" at low qualities, for municipalities who install thousands or hundreds of thousands that becomes ridiculously expensive, so they'll stick to the commercial one.
The added value in arms is the bending, the treated steel pipe is cheap but of course the massive quantity buyer cannot bend the tubes by himself, so they'll charge an important amount for the bending process despite that process is super cheap. They might mold the steel in the bended shape from the beginning, but that "bended shape" charge is still there. Also a bended tube is inefficient to ship, so there's another important cost.
The problem here is he needs a bunch of them so the "cheap" $35 becomes a not so cheap $250 . $250 might as well be a million when you're his age.
That's another problem, and that's why he's looking for a cheaper alternative. For you 35 bucks might be nothing, but for that here you buy groceries for a week and for me that's a couple months savings because I'm still a teen, but then you multiply that 35 bucks and becomes impossible to afford.
Joe Maurath, Jr.
Re: Why are good quality arms so expensive? « Reply #16 on: February 22, 2021, 01:43:47 PM » Author: Joe Maurath, Jr.
For a long time until I got into the utility business, I also found arms very hard to come by. Thus, the fixtures came around somewhat easier.
Binarix128
220V AC 50Hz, NTSC
Re: Why are good quality arms so expensive? « Reply #17 on: February 22, 2021, 05:58:17 PM » Author: Binarix128
Yep, you can sometimes get one or two fixtures for the price of an arm.  :P
Re: Why are good quality arms so expensive? « Reply #18 on: February 22, 2021, 07:50:58 PM » Author: Ash
I have made a pole and arm out of 2" water pipe, using 2 sections and an elbow. This is standing up since 2015 with the heaviest lantern i have in collection - an Elba PVB7A - over 3ft lantern made of solid cast Aluminum of some 7mm thickness
The long pipe (the "pole") is something i found in a scrap but seems to have been unused (no rust on the inner surface), and the elbow, short pipe (the "arm"), and brackets holding the "pole" to the framing of the fence at the end of the garden, have been bought new, for much less than $35 equivalent
There is no rule that everything at the scrap yard is at its end of useful life....
For most things that are scrapped, nobody had been looking up in some notebooks to check the date of installation, and scrapping it at the right moment. It's just removed as part of bigger renovation projects in which much more infrastructure is replaced than just streetlight arms, or just whenever it gets removed for whatever reason
I think if you find something suitable from scrap which appears to be in good condition now (no rust, ...), statistically it will be still good for many more years
Galvanizing layer (zinc plating) is available in a spray can, you can buy it from any metal or welding supplies shop. It is used for repairing the galvanizing in situ after welding etc. It seems that things sprayed with it generally do hold up well
So if you cut/grind/weld anything use it
I think it can be used to restore the protection layer on scrap find parts too (if the existing layer is becoming EOL) ?
