Author Topic: Why not electronic ballast for mercury vapor?  (Read 4412 times)
OgreVorbis
Why not electronic ballast for mercury vapor? « on: February 08, 2021, 11:49:20 PM » Author: OgreVorbis
I've read somewhere here in the past that you're not meant to use an electronic ballast on a mercury lamp. Why is this? Is it a myth?
All other types of arc lamps (LPS, fluorescent, metal halide) work on electronic ballasts, so what makes mercury different?
Bulbman256
Mad Max
Bulbman256
Re: Why not electronic ballast for mercury vapor? « Reply #1 on: February 08, 2021, 11:53:13 PM » Author: Bulbman256
In 2008 all mercury vapor ballast where banned from being made and sold as new OEM parts and fixtures. Electronic ballast started to take of around then, but mercury was banned so no development was considered. :P
OgreVorbis
Re: Why not electronic ballast for mercury vapor? « Reply #2 on: February 08, 2021, 11:58:05 PM » Author: OgreVorbis
Yeah, I know  :(
But the thing is that people are using fluorescent ballasts with them just fine, but for some reason they say to use magnetic fluorescent ballast only :wndr:
Xytrell
Re: Why not electronic ballast for mercury vapor? « Reply #3 on: February 09, 2021, 12:06:03 AM » Author: Xytrell
I don't see any reason a metal halide electronic ballast of the same power rating wouldn't run it close enough.
OgreVorbis
Re: Why not electronic ballast for mercury vapor? « Reply #4 on: February 09, 2021, 12:19:05 AM » Author: OgreVorbis
Check this: https://www.fulham.com/PDFs/SpecSheets/WH5-120-L-2006-26SP.pdf
Probably would run 50W, 75W and 100W. Am I wrong?
Seems way better than messing with old ballasts unless some people just like them. I was under the impression that magnetic was required for the bulb.
Re: Why not electronic ballast for mercury vapor? « Reply #5 on: February 09, 2021, 03:46:04 PM » Author: sol
Electronic MH ballasts have ignitor circuitry built in and cannot be deactivated. While in theory it could work, it has a high probability of destroying the starting resistor in the MV lamp.
I wouldn't try it with a lamp that is valuable...
Bulbman256
Mad Max
Bulbman256
Re: Why not electronic ballast for mercury vapor? « Reply #6 on: February 09, 2021, 03:55:03 PM » Author: Bulbman256
One could use an Eye moonpulse lamp, but good luck finding one. :P
Re: Why not electronic ballast for mercury vapor? « Reply #7 on: February 09, 2021, 07:34:41 PM » Author: Ash
If it would be just about the resistor there would be no problem - Run the lamp on the ballast, and after the first time it will become a Moon Pulse lamp....
But i have seen a case where ignitor voltage destroyed an 125W mercury lamp (connected to 100W MH magnetic ballast with superimposed ignitor) in another way - The glass in the stem press of the outer envelope went into a dielectric breakdown and melted. I guess this happened in a hot restrike
Or you can disable the ignitor in the electronic ballast. They are not built to let you do this normally, but if you open it, in many cases you can figure out what to disconnect or short
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: Why not electronic ballast for mercury vapor? « Reply #8 on: February 09, 2021, 11:11:04 PM » Author: Binarix128
Sticking an MV in an HPS or pulse start electronic ballast will destroy the start probes, you will notice that one end of the MV will get quickly sputtered, if you use a clear MV. A probe start MH ballast should be ok, althought there is still a 750V pulse but it is not that bad.
I think there's no ballast for HPMVs because it would be too complicated and it wouldn't worth due to newer technologies like MH, HPS or LED.
In electronic fluorescent ballasts the output current is limited by the heater cathodes and the low pressure gas, and usually the circuit is closed by a capacitor, but a HPMV is a short circuit, so it is more tricky to operate than a fluorescent tube.
Re: Why not electronic ballast for mercury vapor? « Reply #9 on: February 09, 2021, 11:48:49 PM » Author: wide-lite 1000
Wouldn't a MV lamp work on an electronic probe start MH ballast ?? I remember seeing some on eBay a while ago !
Binarix128
220V AC 50Hz, NTSC
Re: Why not electronic ballast for mercury vapor? « Reply #10 on: February 09, 2021, 11:54:40 PM » Author: Binarix128
It should work perfectly in theory, a MH is mainly based in mercury too so the voltages and currents shouldn't be too different to cause a significant short life.
Re: Why not electronic ballast for mercury vapor? « Reply #11 on: February 10, 2021, 03:53:41 AM » Author: Ash
The discharge cannot limit the current on its own in any lamp (with exception of some ultra high pressure lamps). Its behavior is not a short circuit though (a short circuit would not dissipate any power) but of a constant voltage drop. Without current limiting, connecting any higher voltage source would result in I = (Vsource - Varc) / No resistance = Infinite current. With a ballast, the ballast impedance and the voltage difference set the current
In choke ballasts, the impedance is at 90 deg angle to the voltage, so the same calculation applies but in vector form
In CWAs and some electronic ballasts, the ballast regulates the current directly and it does not depend as much on the lamp behavior
Re: Why not electronic ballast for mercury vapor? « Reply #12 on: February 10, 2021, 04:19:44 AM » Author: Medved
No, it won't destroy the probes. You may use whatever high voltage ignitor, but the voltage would never be above what the lamp allows, so in case of a probe start MV it is about 200V or so. And no, the resistor isn't at danger either, the same thing: The discharge will move to the main electrodes instantly and limit the voltage.
The voltage is always dictated by the lamp, so when the lamp wants 200V, there wont be more than 200V
The voltage printed on the ignitors is, how high they may go only when unrestricted by the lamp. Normally the lamp is supposed to restrict it below that voltage (by the gas breakdown). In fact if the lamp wont restrict it, it means the ignitor wont be able to start the lamp in the first place.
So no, starting cold lamps with a HV ignitor does not do any harm to them, nor the ignitor.
But only when the lamp is cold.
The problem with HV ignitors and probe start lamps is elsewhere:
When the lamp is hot, the breakdown voltage of the gas within the arctube is way higher. That is, why it needs to first cool down before it is able to ignite again. Because the breakdown voltage is high, so will be the voltage the lamp will limit to when e.g. getting pulse form the ignitor. And this may be way above what the internal construction in the outer or socket can withstand without risking its damage. The thing is, lamps that explicitely need HV for the normal ignition have to be designed so they withstand the maximum voltage the ignitor generates when the gas won't break down (e.g. because of the high pressure when hot,...).
But lamps designed to be started without an ignitor normally have to withstand just the couple 100's V the ballast OCV, so they are using different design of the outer (clearances between conductors, gas fill pressure and composition,...). And that construction may break down when exposed to the kV of the ignitor and e.g. start an arc in the outer. Don't forget the elevated pressure is in the arctube, not in the outer bulb. So when the arctube may have safely lower breakdown voltage than the outer when cold, the relation may reverse when the lamp was just extinguished (e.g. by power dip,...)
No. Output current in fluorescent circuit is not limited by the electrodes, nor by the low pressure gas nor anything within the tube. Electrically a thin 6mA CCFL would easily carry many amps of current, only till its destruction of course. Which may happen pretty fast, but since then there is practically nothing to limit the current at all within the lamp itself.
So even with fluorescent circuits, the only thing that limits the current to whatever the lamp is designed for, is the ballast. Regardless what its construction is. So the current limiting component could be an inductor (series choke preheat ballasts, but as well as practically all of the mains electronic ballasts), it could be a capacitor (many CCFL ballasts, some night lights, many "royer oscillator" based DC input fluorescent ballasts like in emergency fixtures,...), it may be an output characteristic of a flyback inverter (the low cost battery powered inverters, some emergency fixtures,...), sometimes a resistor (fluorescent lights in old trams, old HV battery powered fluorescent lanterns, some early cheepeese light fixtures using incandescent lamps or even a resistor element,...), but it is always the ballast, what says what current will flow there.
The problem with high pressure lamps on electronic fluorescent ballasts is, fluorescent ballasts use to operate at high frequency AC. That is good for the low pressure style discharge, because it pushes the current density more towards the discharge surface, so operates it at lower current density where the light generation is more efficient and closer to the walls, so with less path for the light to travel so lower self absorbtion here. Plus high frequency means the reactive components (mainly coils) are smaller, so could easily be designed with way lower losses (mains frequency coil uses to dissipate about 5% of he VAs the coil is exposed at, the high frequency coil below 0.1% of he similar VAs; but with electronic ballasts the rest of the circuit means other losses).
But the high pressure lamps are usually small, so their acoustic resonance uses to be higher frequency close where the electronic ballasts operate and with high quality factor, so may develop very strong resonance effects leading to standing waves causing local overload of the arctube. There many ways to address this in HID ballasts (frequency wobbling, use of low frequency square wave feed,...), but as the fluorescent tubes do not exhibit these issues, ballasts designed for fluorescent feature no explicit measures against the lamp resonance.
Re: Why not electronic ballast for mercury vapor? « Reply #13 on: April 02, 2025, 02:41:59 AM » Author: WorldwideHIDCollectorUSA
I have read somewhere that Japan supposedly manufactured some electronic ballasts designed for mercury vapor lamps, but not totally sure if that was the case or not.
Re: Why not electronic ballast for mercury vapor? « Reply #14 on: April 02, 2025, 05:40:05 PM » Author: James
In theory it could be possible to make an HPMV lamp to run on electronic ballast but there is little point in lighting applications, because the luminous flux and efficacy both drop by a small amount.
The plasma temperature is increased on a high frequency ballast, which caused preferential ionisation of energy transitions that radiate in the UV wavelengths.  So UV-B output increased while visible decreases.  Electronic ballasts are therefore quite common for UV mercury lamps.
Regarding the starting resistor, indeed it can be a problem that flashover will occur across that.  Sylvania used to make special HSB-BW lamps of 80/125/250/400W for sale to Italy, where mercury lamps were often wired in long series chains from a single large current regulator.  If one lamp in the chain did not strike the full open circuit voltage of several kV was applied across the resistor and the surrounding gas filling would arc, dissipate a high power, and melt the lamp’s internal construction.  We used to put two resistors in series for lamps sold to Italy, halving the voltage gradient across the resistor, and to use a higher pressure nitrogen fill in the outer bulb to avoid such damage.
