1st : disconnect the 3 wire plug going to the low voltage indicator on the door . (for some reason my indicator freaked out when I powered it up with the P/C bypassed ) no idea WHY !
2nd : hook your white power wire to white , green to the ground screw and connect the black to the center space on the terminal block ( it should have a red wire and a black wire attached there) this will power your light whilst eliminating the need for a P/C .
If you ever want to run it with a P/C , simply re-attach the 3 wire plug and move the black power wire to the space on the terminal block that has all black wires on it .
Thank You - I have successfully connected and powered up the fixture using your instructions bypassing the PC.
I also had an untested Fisher-Pierce 6660 PC that I got from a "roadkill" ITT Model 13 many years ago. I inserted it into the new Cooper OVZ/NYC socket, moved the black wire to the black terminal, connected the harness for the low-voltage indicator,and the light powered right up, regardless of dark or light. I'm thinking the PC is no good. Can you recommend a new PC for the Cooper?
Lou
