November 23, 2024, 06:53:18 PM
Vintage & Antique
did i get this wiring correctly?
Topic: did i get this wiring correctly? (Read 1460 times)
Walter Knox
« on: February 01, 2021, 10:19:49 PM »
Walter Knox
I am going to be removing a fixture that takes 2 f20t12 lamps from my friends house on Thursday, it has an old keystone rapid start ballast from the 90s that still works but buzzes quite loudly. i had this preheat ballast laying around that works good and was NOS when i got it, i used it for like a year and removed it. sadly where it was located was damp and the label kind of got warn off some. i made this note card with what i believe is the correct wiring from wiring them in the past and what I can see on the label, i don't want to blow anything up so i am just asking if this looks okay before i do anything.
nogden
Nelson Ogden
Re: did i get this wiring correctly?
« Reply #1 on: February 02, 2021, 09:13:16 AM »
nogden
Yes, you got it right!
Walter Knox
« Reply #2 on: February 02, 2021, 09:14:12 AM »
Walter Knox
thank you.
alexd120
« Reply #3 on: February 02, 2021, 02:58:59 PM »
alexd120
Looks correct to me
Rapid start ,preheat metal halide mercury vapor and high pressure sodium for life.
« Reply #4 on: February 03, 2021, 09:40:34 AM »
Author: sox35
If I were to be really picky, it's L(ine) or P(hase) and N(eutral) for the supply, not + and - which is DC. Otherwise it's fine
© 2005-2024 Lighting-Gallery.net
