Author Topic: Will this work with this?  (Read 16853 times)
JECWhiz
Will this work with this? « on: October 01, 2006, 02:10:57 PM » Author: JECWhiz
I am getting one of those....
http://www.lighting-gallery.net/gallery/displayimage.php?pos=-8657
and I am wondering if this Netherlands light that works on 240 volts, 50 Hz will work on this
http://traveloasis.com/transformers5.html
Since I live in USA......and the outlets in USA is 120 volts, 60 Hz.....and I want to plug in a light that uses 240 volts and 50 Hz....so I was wondering if this step up transformer would work or not.....
If someone knows...please let me know!
dp
Re: Will this work with this? « Reply #1 on: October 01, 2006, 04:48:23 PM » Author: dp
Hi Jace,
I'd imagine that it works on the XGS 103. The voltage will work up to just over 250v and just under 220v.
Hope this helps
JECWhiz
Re: Will this work with this? « Reply #2 on: October 01, 2006, 08:09:53 PM » Author: JECWhiz
Even if the the voltage of the outlet might be 60hz instead of 50hz????
they were made for 240 volts 50hz
but I think...but I maybe wrong....but the voltage that comes out of the step up transformer is 60hz....so would a 240 volts 50hz work on a 240 volts 60hz?
dp
Re: Will this work with this? « Reply #3 on: October 02, 2006, 01:33:49 PM » Author: dp
I think that they have a switchmode supply that converts it to a few kHz-MHz then back to 50Hz. If anyone can correct us then please do so.
JECWhiz
Re: Will this work with this? « Reply #4 on: October 02, 2006, 04:15:12 PM » Author: JECWhiz
I donno because none of the pages says it will convert to 50hz.....
but would a 240 volts 60hz still work with the Netherlands LPS light?
