Author Topic: What's your first bulb from 2021?  (Read 3214 times)
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
What's your first bulb from 2021? « on: January 01, 2021, 01:05:37 PM » Author: Binarix128
Continuing with the what's your last bulb from 2020 topic, I'm gonna ask you guys what's your first bulb from this year.
My first bulbs are some more various voltages incandescent flashlight bulbs, and some color LED diodes I recycled from toys.
My first lighting stuff is an incandescent optic fiber lamp, and found battery powered incandescent ceilings.
High Intensity
Re: What's your first bulb from 2021? « Reply #1 on: January 01, 2021, 07:48:14 PM » Author: High Intensity
I went to Lowes today and got a few bulbs on clearance, those bulbs are...
6 (Philips made) GE F48T12HO tubes.
A GE 100w MV.
And a pack of two GE F32T8 LED Tubes (6500K, US-Made).
Re: What's your first bulb from 2021? « Reply #2 on: January 01, 2021, 11:40:40 PM » Author: joseph_125
First lighting related purchase of 2021 is a couple of USB powered RGB LED strips.
BGPATTERSON403
Re: What's your first bulb from 2021? « Reply #3 on: January 02, 2021, 12:21:06 PM » Author: BGPATTERSON403
Two F96T12/cw/HO lamps for my garage.  I found end caps and sockets to make them fit. Just need a suitable ballast. Maybe a 2s110, ill have to Google other part numbers.
Re: What's your first bulb from 2021? « Reply #4 on: January 02, 2021, 01:02:27 PM » Author: sox35
We've still got some from our big haul of last October to put up, so if that counts it will be a Philips Powertone 50W MV, which is lit at the moment, photos to follow.
Re: What's your first bulb from 2021? « Reply #5 on: January 02, 2021, 09:07:06 PM » Author: wide-lite 1000
I don't know if this applies or not , I received my new lighted keyboard for my computer today . All keys are back lit with white LEDs and have larger print on them . ( I can't see as good as I could when I was younger !)  :(
Re: What's your first bulb from 2021? « Reply #6 on: January 03, 2021, 12:59:30 AM » Author: xmaslightguy
@wide-lite 1000:
It lights up...so in my book that keyboard counts.
Re: What's your first bulb from 2021? « Reply #7 on: January 03, 2021, 06:33:38 AM » Author: sox35
@wide-lite 1000:
Yeah, but they're indicators, not proper lamps. The only valid use for them things in my book  :P
RadxD461
Re: What's your first bulb from 2021? « Reply #8 on: January 03, 2021, 09:45:07 AM » Author: RadxD461
a Philips Westinghouse lamps bt25 100MV lamp.
HPS_250
Long live the HPS and SOX!
UCAjfrNb4v77ybEBBYqxZxiw
Re: What's your first bulb from 2021? « Reply #9 on: January 04, 2021, 10:03:58 PM » Author: HPS_250
It will be a GE Mazda 25w inside frost. My second lamp will likely be a Philips Lifeguard 75w MV.
Bulbman256
Mad Max
Bulbman256
Re: What's your first bulb from 2021? « Reply #10 on: January 04, 2021, 10:28:23 PM » Author: Bulbman256
I bought a 100w g40 sylvania globe lamp, a pair of 25w Phillips duramax lamps, and soem sylvania 15w a15 lamps. :)
desktoptrashcan
theroadrunner556
Re: What's your first bulb from 2021? « Reply #11 on: January 04, 2021, 10:50:03 PM » Author: desktoptrashcan
GE green dichro-color
Mazda 25W incandescent bulb
HPS_250
Re: What's your first bulb from 2021? « Reply #12 on: January 04, 2021, 11:25:52 PM » Author: HPS_250
Nice finds. Can you post pictures of the green Dichro-Color when it arrives?
desktoptrashcan
theroadrunner556
Re: What's your first bulb from 2021? « Reply #13 on: January 04, 2021, 11:37:48 PM » Author: desktoptrashcan
Will do.  :)
BT25
Re: What's your first bulb from 2021? « Reply #14 on: January 07, 2021, 09:06:38 PM » Author: BT25
My first finds for 2021 are posted HERE.
« Last Edit: January 08, 2021, 06:27:50 PM by BT25 » Logged
