Bulbman256
Mad Max
fluorescent lover 40
I think the best wattage you get is either 35w or 55w. As for substitutes, don't know much about those.
I did find that for my 35w SOX lamp, I managed to drive the lamp at about 0.53a when using my 35/39w MH ballast and that current reading is pretty close to the 0.6a these lamps are designed to run at. I did get approval from funkybulb that these lamps were safe on 35/39w M130 MH ballasts after learning to use an amp meter.
« Last Edit: December 08, 2020, 12:39:57 AM by WorldwideHIDCollectorUSA »
In terms of the lamps, 35 and 55w lamps are still reasonably priced. I believe 18w lamps are too if you're in the US.
Bulbman256
Mad Max
If that ran the lamp ok, i could try getting one to also do 50w mv lamps. Got a recommendation for good igniters?
Binarix128
220V AC 50Hz, NTSC
I recommend you getting a 18W SOX, you can run it with a regular 18W preheat gear with an S10 starter, but you will need a 120V SOX or a 240V gear and mains. Here's the schematic of how to run an 18W SOX on a fluorescent gear.
This setup only seems to work reliably on 240v gear as the setup I have used seems to kill ignitors on 120v mains.
I believe a Fullham Workhorse 2 will run a 18w SOX at almost spot on if you're ok with using an electronic ballast.
Binarix128
220V AC 50Hz, NTSC
It might work if he buys a 240V SOX and gear and running all between two 120V phases from the oven outlet.
I've managed to get a SOX 18 to strike on a 240v 20w choke before with a S10 starter. Running off a small step up transformer to get the 240v. A magnetic PL ballast with a similar wattage might also work. The PL ballasts have a small stepup in them as PL lamps a above 13w here need a autotransformer style ballast. So maybe one of those and a FS-4 starter in parallel with the lamp.
I believe FS-4 and S10 starters are fairly interchangeable with each other.
Rodalco
I have good success with a 70W HPS ballast in series with a 36/40 Watt fluro ballast and a hps N70 igniter. I use 35 Watt SOX lamps. Supply 240 Volts at 320 mA.
A SOX lamp lighting up is like the sunrise on a beautiful day
RadxD461
