Author Topic: Advice on finding the cause of unknown (electrical?) buzzing sound?  (Read 1190 times)
HPS_250
Long live the HPS and SOX!
UCAjfrNb4v77ybEBBYqxZxiw
Advice on finding the cause of unknown (electrical?) buzzing sound? « on: December 07, 2020, 01:13:25 PM » Author: HPS_250
I am not sure if this sound is electrical, or if it is caused by something else such as vibration. Today is very windy, so it could possibly be caused by some kind of vibration. Coming from the wall between my laundry room and living room, there is a slight buzzing sound. The only electrical items nearby are an outlet and a switch box. There are some electronics on the table/cabinet next to the wall, including a TV (turned off), subwoofer, and WiFi router. I will check later if the sound goes away upon unplugging anything. Does anyone have advice on finding the cause of this sound?
Re: Advice on finding the cause of unknown (electrical?) buzzing sound? « Reply #1 on: December 07, 2020, 01:42:06 PM » Author: Mandolin Girl
You're going about it in the correct way.  :bulbman:
Unplug everything and plug them back in one by one until the humming starts up again.
If it's still there after unplugging everything a more in-depth investigation will be needed.  :wndr:
HPS_250
Re: Advice on finding the cause of unknown (electrical?) buzzing sound? « Reply #2 on: December 07, 2020, 02:25:22 PM » Author: HPS_250
Thanks, I will try unplugging everything and testing for the sound later when I have time. I’ll report back if I find out the cause of it.
Re: Advice on finding the cause of unknown (electrical?) buzzing sound? « Reply #3 on: December 07, 2020, 02:27:54 PM » Author: Mandolin Girl
No problem, I like to help when I can, in between introducing some levity onto the site.  :'-)
Re: Advice on finding the cause of unknown (electrical?) buzzing sound? « Reply #4 on: December 07, 2020, 02:46:12 PM » Author: WorldwideHIDCollectorUSA
Does this buzzing produce a mains hum such as a 60hz hum in your case?
HPS_250
Re: Advice on finding the cause of unknown (electrical?) buzzing sound? « Reply #5 on: December 07, 2020, 03:05:31 PM » Author: HPS_250
It sounds like a mains hum or 60Hz hum as far as I can tell, because it is not loud or high-pitched. There was another high-pitched hum in the same area, which turned out to be the TV power supply.
Re: Advice on finding the cause of unknown (electrical?) buzzing sound? « Reply #6 on: December 07, 2020, 05:02:11 PM » Author: Medved
I have a switch (used in kitchen to disconnect power to the stove), which tends to make noise even when the stove is off. It is no sparking, just probably something like piezoelectricity in the bakelite (base material for holding tge contacts).
So if unplugging things wont lead to anything conclusive, you may try to shut down the breakers of all the circuits around, one by one.
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: Advice on finding the cause of unknown (electrical?) buzzing sound? « Reply #7 on: December 07, 2020, 05:04:46 PM » Author: Binarix128
On my bathroom, there's a hose vibrating at 100Hz. No mains involved, just the given conditions like the length, the width and the quantity of water passing. At the beginning I thought it was actually the mains, but then I casually twisted the hose and the frequency changed. In your case it can be anything but not the mains, cut off the power if you can, if it the sound keeps check the hoses and the piping.
Re: Advice on finding the cause of unknown (electrical?) buzzing sound? « Reply #8 on: December 07, 2020, 05:28:28 PM » Author: Ash
Water hammer perhaps might end up close to the line frequency for a reason : The water is pumped by an asynchronous motor at the pump station, and under certain conditions could be conducting the vibration from there over the water supply, perhaps for quite some distance, especially if you have something on your end that would rattle in sync.... The actual sound frequency in this case will be ~0.95 of the electrical supply frequency
In your case, switch off breakers and see if it goes
Also try to record it, record some genuine line frequency hum, open the recordings on the computer in Audacity and compare the exact frequency. If it is not the same or an exact multiple, then it is not electrical. (An exception, once again, to asynchronous motors running at a slip)
