Author Topic: Are there any US members who use voltages higher than 120v for lighting?  (Read 1327 times)
Are there any US members who use voltages higher than 120v for lighting? « on: November 26, 2020, 04:43:42 PM » Author: WorldwideHIDCollectorUSA
Just curious if any US members besides funkybulb, silverliner, xmaslightguy, and DieselNut who use voltages higher than 120v for lighting such as 208v, 277v, 347v, and 480v?
« Last Edit: November 26, 2020, 04:45:36 PM by WorldwideHIDCollectorUSA » Logged
HPS_250
Long live the HPS and SOX!
UCAjfrNb4v77ybEBBYqxZxiw
Re: Are there any US members who use voltages higher than 120v for lighting? « Reply #1 on: November 26, 2020, 04:53:51 PM » Author: HPS_250
I just use regular old 120v, and that’s all that is available in my house because appliances that would normally used 240v (oven, stove, dryer, etc.) are all natural gas.
Re: Are there any US members who use voltages higher than 120v for lighting? « Reply #2 on: November 26, 2020, 06:19:20 PM » Author: wide-lite 1000
I do ! My 1000w Wide-Lite is currently wired to 240v 60hz . Eventually , all of my exterior HID lights will be hooked to 240v .
I have several streetlights that have ballasts only rated for 240v or higher.
« Last Edit: November 26, 2020, 06:35:18 PM by wide-lite 1000 » Logged
Re: Are there any US members who use voltages higher than 120v for lighting? « Reply #3 on: November 27, 2020, 12:59:53 AM » Author: tolivac
I have two 1Kw CMH lights that need 240V primary voltage to their ballasts.Use a 2Kva 120-240 step up transformer.Works just fine.
HPS_250
Re: Are there any US members who use voltages higher than 120v for lighting? « Reply #4 on: November 27, 2020, 11:18:20 AM » Author: HPS_250
Any photos? I’d be interested to see what 1000w CMH lamps look like.
Xytrell
Re: Are there any US members who use voltages higher than 120v for lighting? « Reply #5 on: November 27, 2020, 11:38:19 AM » Author: Xytrell
I've got easy access to 240V in several points so I opt for 240V for anything 400W and above for the regular reasons: lower current, higher efficiency, and intrinsic balancing of split phase current draw.
The 1500W halide ballast I have is 480V-only, for which I use a 750VA transformer (in boost-mode, not step-up). I've also got an obscure high power fluorescent ballast heavily discounted since it was 277V only that I run with a couple old scrap low voltage transformers in boost mode. That's about the only way to run 135W LPS lamps I've found that doesn't anger the pocketbook.
« Last Edit: November 27, 2020, 07:41:28 PM by Xytrell » Logged
Re: Are there any US members who use voltages higher than 120v for lighting? « Reply #6 on: November 27, 2020, 01:10:55 PM » Author: xmaslightguy
I have a 5' switch-start fluorescent fixture with UK ballasts, and a UK 8' ballast attached to a board (currently running a 7' HO lamp).
Use a  step-up transformer to power them.
Re: Are there any US members who use voltages higher than 120v for lighting? « Reply #7 on: November 27, 2020, 01:24:20 PM » Author: WorldwideHIDCollectorUSA
Are there US members who also use 480v as well?
Re: Are there any US members who use voltages higher than 120v for lighting? « Reply #8 on: November 27, 2020, 04:15:55 PM » Author: RyanF40T12
Many of my church buildings I help maintain use 208 and 240 volt for the parking lot lights, but most are still 120.
