Author Topic: Is this ballast a CWA ballast?  (Read 3303 times)
Is this ballast a CWA ballast? « on: November 21, 2020, 05:33:25 PM » Author: WorldwideHIDCollectorUSA
I just received a ballast that was supposedly said to be a HX ballast because it did not feature a capacitor in the wiring diagram but it does say the word “cap” on the live lamp wire. It does say that it is an isolating transformer on it. I tested the ballast to see if it works and I found out that it does fire up lamps without a capacitor in series with the lamp. Does this mean that this ballast is a CWA and NOT a HX and that it will get damaged if I use certain HPS retrofit lamps in it like the sylvania unalux and westinghouse econolux lamps?
« Last Edit: November 21, 2020, 05:50:24 PM by WorldwideHIDCollectorUSA » Logged
Re: Is this ballast a CWA ballast? « Reply #1 on: November 21, 2020, 07:34:45 PM » Author: sol
I’d say it is CWI because the label and wiring diagramme suggest it. There is a wire labeled cap but no mention of it on the label. Does it have some kind of protusion that could house a capacitor ? Also, the label says high power factor, so it must use some kind of cap somewhere in the circuit.
Re: Is this ballast a CWA ballast? « Reply #2 on: November 21, 2020, 08:18:42 PM » Author: icefoglights
It may rely upon a cap across the supply wires.
Re: Is this ballast a CWA ballast? « Reply #3 on: November 21, 2020, 08:25:12 PM » Author: WorldwideHIDCollectorUSA
It did have a capacitor connector that I removed since it had exposed wire.
Re: Is this ballast a CWA ballast? « Reply #4 on: November 21, 2020, 08:30:40 PM » Author: WorldwideHIDCollectorUSA
I also see that this ballast does not specify the microfarad value for the capacitor.
Re: Is this ballast a CWA ballast? « Reply #5 on: November 21, 2020, 08:39:08 PM » Author: WorldwideHIDCollectorUSA
Should I also be worried about underdriving 400w H33 MV lamps and HPS retrofit lamps for 400w MV lamps? Should I also worry about this ballast getting damaged if I use Sylvania Unalux or Westinghouse Econolux retrofit lamps?
Re: Is this ballast a CWA ballast? « Reply #6 on: November 22, 2020, 02:31:15 AM » Author: Medved
The fact it is a HPF and yet it does not specify any capacitor is really very strange, because it is just not possible without one.
So it seems they have omitted the capacitor from the wiring diagram (because hard wired? And what else they omitted?). But then it could be essentially anywhere, so it could be any topology (CWA/I, as well as HX with power factor compensation on the primary).
Maybe if you have any chance to measure the phase of the input current (if it is leading or lagging to the voltage), you may distinguish CWx from HX when measuring it without any load connected:
If the phase is capacitive, it is HX.
If it is inductive, it is CWx.
Re: Is this ballast a CWA ballast? « Reply #7 on: November 22, 2020, 02:44:20 AM » Author: WorldwideHIDCollectorUSA
I also notice this ballast does not have the words “constant wattage” or the letters “CW” written on it.
Re: Is this ballast a CWA ballast? « Reply #8 on: November 23, 2020, 04:51:40 AM » Author: Medved
That does not mean it cannot be a CWA/CWI.
Re: Is this ballast a CWA ballast? « Reply #9 on: November 23, 2020, 04:16:14 PM » Author: WorldwideHIDCollectorUSA
How can I determine if the phase is capacitive or inductive?
Re: Is this ballast a CWA ballast? « Reply #10 on: November 24, 2020, 02:56:40 AM » Author: Medved
With a power meter able to explicitely display reactive power. Some allow that,but many, indeed, dont.
You may determine it ar low voltage (e.g. 12 or 24V from a transformer), thenyou may connect some series resistor to the supply and use an oscilloscope to determine the phase. The lead vs lag behavior will stay the same, even at such low voltage, but it will be safe to mess with the grounded oscilloscope.
Otherwise if youhave an isolation transformer and an oscilloscope, youmay check the phase on the load (it has to be connected tothe lamp). If the load phase leads, it is a CWA, if it lags, it is HX.
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: Is this ballast a CWA ballast? « Reply #11 on: November 24, 2020, 07:47:32 AM » Author: Binarix128
You can determine the type of load by looking at the oscilloscope waveform. A normal power meter with a power factor indication may work, and you can do the experiments at full voltage and without extra transformer.
The capacitive load lags the current and tend to have a power factor of 0, the inductive load leads the current but I don't know its power factor.
The previous pictures are from this video.
Re: Is this ballast a CWA ballast? « Reply #12 on: November 24, 2020, 04:30:33 PM » Author: Medved
@Binarix128: You've found very nice pictures for that...
Binarix128
220V AC 50Hz, NTSC
Re: Is this ballast a CWA ballast? « Reply #13 on: November 24, 2020, 05:51:06 PM » Author: Binarix128
Thanks! But I'm still not sure what is the power factor of a pure inductive load, and if we add a capacitor the factor becomes 1.
Re: Is this ballast a CWA ballast? « Reply #14 on: November 24, 2020, 06:38:29 PM » Author: Medved
PF = 1/Q ...
So with a loss less inductor it would be zero: Because zero losses means zero real power, with some reactive power.
And if we add a perfectly matching loss less capacitor to a loss less inductor, the PF = 0 / 0, so undefined... It will just appear as a pure open circuit. The magic of resonance...
