Author Topic: Is this ballast a CWA ballast?  (Read 3306 times)
Re: Is this ballast a CWA ballast? « Reply #15 on: December 10, 2020, 04:47:03 PM » Author: WorldwideHIDCollectorUSA
Can I also determine whether this ballast is CWA or HX by seeing if the lamp is being correctly driven with or without the capacitor?
Re: Is this ballast a CWA ballast? « Reply #16 on: December 10, 2020, 09:44:36 PM » Author: dor123
Yes. If the lamp operates at full output without a capacitor, the ballast is HX, if it is underdriven without a capacitor, so CWA.
Re: Is this ballast a CWA ballast? « Reply #17 on: December 10, 2020, 11:22:40 PM » Author: Medved
It uses to be that way with many ballasts, but I would not rely on it. It depends, how exactly is the ballast designed.
Re: Is this ballast a CWA ballast? « Reply #18 on: December 17, 2020, 10:01:12 PM » Author: WorldwideHIDCollectorUSA
After doing tests on this 400w MV ballast without using a capacitor and using the proper 400w MV lamp, I have found out that the lamp is driven at about 3.3a, which is fairly close to the needed 3.25a for operation. As a result, should this be a clear indication that my ballast is a true HX Isolating ballast?
Re: Is this ballast a CWA ballast? « Reply #19 on: February 07, 2021, 04:12:15 PM » Author: WorldwideHIDCollectorUSA
After doing tests on the ballast without a capacitor, I noticed that the total wattage on the ballast with the proper lamp was about 275w. I can be pretty sure that this leads me to think that it is a CWI ballast.
