Author Topic: Are most HID ballasts in the world 220-240v series chokes?  (Read 876 times)
Are most HID ballasts in the world 220-240v series chokes? « on: November 18, 2020, 03:56:03 PM » Author: WorldwideHIDCollectorUSA
I am curious about this because I see that many countries in the world use series choke ballasts designed for 220-240v supplies on either 50 or 60hz.
Re: Are most HID ballasts in the world 220-240v series chokes? « Reply #1 on: November 19, 2020, 12:13:40 PM » Author: Medved
In all 230V world (read: All countries using 220..240V as home socket mains voltage), anything else than a series reactor choke as a magnetic ballast is practically unheard of (beside some really special lamps the LPS and early adoption of probe start MH were the exceptions I know of, both turned to a series choke too once electronic ignitors became available, the MH became quickly replaced by pulse start lamps running againfrom just a series choke - because pulse lamps were much cheaper and/or way better performing).
Either connected to 230V for most wattages, or to 400V across phases for some 1kW and above with ~200V arc (still with just a series choke as the ballast).
Re: Are most HID ballasts in the world 220-240v series chokes? « Reply #2 on: November 19, 2020, 10:07:35 PM » Author: WorldwideHIDCollectorUSA
I see that some 120v countries in Latin America also use 240v series chokes for their HID lamps such as Colombia and Venezuela.
Re: Are most HID ballasts in the world 220-240v series chokes? « Reply #3 on: November 20, 2020, 03:11:35 AM » Author: Medved
If there it is most common to use 240V for HID, I wouldn't be surprised they adopt the "European" style ballasts and lamps (of course, ballasts need to be designed for 60Hz instead of 50Hz).
