Author Topic: Does anyone know of Sylvania Metalarc Swingline lamps?  (Read 2090 times)
Does anyone know of Sylvania Metalarc Swingline lamps? « on: November 17, 2020, 11:22:37 PM » Author: WorldwideHIDCollectorUSA
Has anyone known that Sylvania GTE made metal halide lamps that retrofit into mercury vapor ballasts without any modifications at all? These lamps are known as the Metalarc Swingline lamps and were only produced in the 1970s. They were only available in 400w. When you search for these lamps, look for the following part numbers:
MM400/BU-HOR
MM400/BD
MM400/C/BU-HOR
MM400/C/BD
« Last Edit: November 17, 2020, 11:31:28 PM by WorldwideHIDCollectorUSA » Logged
Silverliner
Rare white reflector
Re: Does anyone know of Sylvania Metalarc Swingline lamps? « Reply #1 on: November 18, 2020, 12:31:04 AM » Author: Silverliner
Yup, I sure do. Sylvania’s answer to the GE I-Line. I will be posting a pic later this weekend if time permits.
Member of L-G since 2005.
Electrician.
LandryB
Re: Does anyone know of Sylvania Metalarc Swingline lamps? « Reply #2 on: November 21, 2020, 09:30:42 PM » Author: LandryB
Did these have a diode circuit inside the lamp?  Were they Sodium-Scandium chemistry, or Sodium-Thallium-Indium?
Re: Does anyone know of Sylvania Metalarc Swingline lamps? « Reply #3 on: November 21, 2020, 10:11:00 PM » Author: WorldwideHIDCollectorUSA
I just dont know the chemistry since I never saw any photos of these lamps.
Re: Does anyone know of Sylvania Metalarc Swingline lamps? « Reply #4 on: December 09, 2020, 06:09:51 PM » Author: James
These types had NTI chemistry in the beginning, because the NaSc types are mores susceptible to hyrdogen iodide contamination during life, which leads to rising reignition voltages.  The result of that would be too short a lamp life when used on regular mercury ballasts.  The invention of the barium peroxide getter by Sylvania somewhat improved this problem in the general lighting lamps, but I am not sure if their later Swingline lamps then changed to NaSc fills.  It would be interesting if Dave could light his and check whether or not it shows thallium green colour as it begins to run up!
