Author Topic: Did major ballast manufacturers ever make HX mercury vapor ballasts in 250w+?  (Read 2645 times)
Did major ballast manufacturers ever make HX mercury vapor ballasts in 250w+? « on: November 17, 2020, 11:09:41 PM » Author: WorldwideHIDCollectorUSA
Were there any US ballast manufacturers such as Advance, Magnetek, or Sola that made replacement HX mercury vapor ballasts for 250w H37, 400w H33, 1000w H36, and 1000w H34 mercury vapor lamps that had 120v taps?
« Last Edit: November 17, 2020, 11:12:19 PM by WorldwideHIDCollectorUSA » Logged
Re: Did major ballast manufacturers ever make HX mercury vapor ballasts in 250w+? « Reply #1 on: November 18, 2020, 12:06:42 AM » Author: Lumex120
I've wondered the same thing, and from what I have seen, they never did. They were only really available when you ordered a fixture with an HX ballast. I do want to know who makes 200-250w HPS HX ballasts that AEL and Cooper offer as options in some of their fixtures too.
Unofficial LG Discord
Silverliner
Rare white reflector
Re: Did major ballast manufacturers ever make HX mercury vapor ballasts in 250w+? « Reply #2 on: November 18, 2020, 12:34:05 AM » Author: Silverliner
Yes HX was made up to 400w. 400w mercury street lights had this as an option. I believe reactor/chokes were made up to 1000w.
Member of L-G since 2005.
Electrician.
Re: Did major ballast manufacturers ever make HX mercury vapor ballasts in 250w+? « Reply #3 on: November 18, 2020, 12:42:25 AM » Author: Lumex120
The amp draw from a 1,000w reactor ballast with no cap must be insane.
Re: Did major ballast manufacturers ever make HX mercury vapor ballasts in 250w+? « Reply #4 on: November 18, 2020, 12:51:56 AM » Author: wide-lite 1000
Yes . My GE ballast catalog lists a 400w MV HX as GE part # 15G6250 . Specs: 120v LPF-Autotransformer , 440 input watts , 7.0 input amps , ballast circuit type - LAG .
Re: Did major ballast manufacturers ever make HX mercury vapor ballasts in 250w+? « Reply #5 on: November 18, 2020, 12:54:46 AM » Author: joseph_125
Advance made HX-NPF 250w ballasts available as either a core and coil, or a preassembled version intended to be a bolt on replacement for NEMA heads.
71A3802 is the model for the core and coil, 71A3801-791 is the NEMA replacement. Both are 250w H37 HX NPF ballasts for 120v operation.
It's actually better than a 400w 120v HX-NPF ballast if you're talking about a 480v reactor for H36. A 240v reactor for H34 would probably draw just a bit more. Assuming a 0.65 PF and a total input wattage of 1080w for a 1kW, 425w for a 400w, a 480v H36 would draw around 3.5A. A 240v H34 would draw around 6.7A. Finally a 400w 120v HX-NPF would draw around 5.4A
Re: Did major ballast manufacturers ever make HX mercury vapor ballasts in 250w+? « Reply #6 on: November 18, 2020, 02:06:33 AM » Author: WorldwideHIDCollectorUSA
I wonder why there were so few 1000w HX ballasts for H36 and H34 lamps?
Re: Did major ballast manufacturers ever make HX mercury vapor ballasts in 250w+? « Reply #7 on: April 27, 2021, 03:41:39 AM » Author: WorldwideHIDCollectorUSA
I am also interested in knowing if Advance also made 400w H33 HX mercury vapor ballasts with a 120v tapping. If so, I would be interested in knowing its part number.
Re: Did major ballast manufacturers ever make HX mercury vapor ballasts in 250w+? « Reply #8 on: April 28, 2021, 02:44:29 PM » Author: Medved
Using ballasts without PF caps make sense when used on a multiple phases with a common Neutral (e.g. in Y arrangement in case of 3 phases). The PFC capacitors are then connected across the phases (in Delta). This arrangement prevents eventual resonant effects causing severe overcurrents in case the Neutral breaks. But it is usable only when all phases are switched together with a single contactor/switch.
Re: Did major ballast manufacturers ever make HX mercury vapor ballasts in 250w+? « Reply #9 on: May 30, 2021, 03:43:42 PM » Author: WorldwideHIDCollectorUSA
I am also wondering if there was such a thing as a 1000w H36 mercury vapor HX autotransformer ballast that could run on either 120v or 240v 60hz mains supplies and whether there were any fixtures that used such ballasts as I am looking for a way to operate a Sylvania 880w Unalux high pressure sodium retrofit lamp on a 120v mains supply.
Re: Did major ballast manufacturers ever make HX mercury vapor ballasts in 250w+? « Reply #10 on: December 25, 2024, 10:53:46 PM » Author: WorldwideHIDCollectorUSA
A thing that I know about single coil reactor ballasts without a power factor correction capacitor is that the current draw is basically the same as the lamp current. For example, low power factor reactor ballasts for 1000W H36 mercury vapor lamps should draw around 4.0A while low power factor reactor ballasts for 1000W H34 mercury vapor lamps should draw around 8.0A or so.
Re: Did major ballast manufacturers ever make HX mercury vapor ballasts in 250w+? « Reply #11 on: December 30, 2024, 10:19:15 PM » Author: wide-lite 1000
 I bought a pair of CGE 1000w H-36 core and coil ballasts from eBay awhile back which were HX as far as I could tell . Both were 120v  The wiring diagram didn't show a capacitor . UNFORTUNATELY , due to careless packing by the seller , all that arrived was an empty box with a large taped up hole in the side !!  :curse: :curse: :curse: :curse: :curse:
Baked bagel 11
Tom
Re: Did major ballast manufacturers ever make HX mercury vapor ballasts in 250w+? « Reply #12 on: December 30, 2024, 11:25:11 PM » Author: Baked bagel 11
It never fails to amaze me just how lazy some people are.
Long live the Cobra Heads of America!
Re: Did major ballast manufacturers ever make HX mercury vapor ballasts in 250w+? « Reply #13 on: January 05, 2025, 08:44:14 AM » Author: wide-lite 1000
 This idiot literally put 2-1kw ballasts loose in a single layer cardboard box with -0- packing or stabilization !!!  :poof:
 Definitely a good justification for more chlorine in the gene pool !  :lol:
Baked bagel 11
Tom
Re: Did major ballast manufacturers ever make HX mercury vapor ballasts in 250w+? « Reply #14 on: January 06, 2025, 02:21:46 AM » Author: Baked bagel 11
 :lol:
