Author Topic: 35/39w Open Rated CMH Lamp  (Read 2213 times)
35/39w Open Rated CMH Lamp « on: November 14, 2020, 05:03:43 PM » Author: joseph_125
Anyone know of such a beast? I have a few ideas for a project that could use one of these. I know the PAR20 and PAR30 lamps are open rated but I'm wondering if they made the any non reflectored open rated models. As far as my knowledge, no one makes a 35/39w CMH in the ED17 envelope nor do any G12 based 35/39w CMH lamps exist.
Re: 35/39w Open Rated CMH Lamp « Reply #1 on: November 14, 2020, 11:01:12 PM » Author: wide-lite 1000
Here's a G12 35w CMH . It's not open rated though :
https://www.ebay.com/itm/New-Hg-Ceramic-Metal-Halide-Lamp-CMH-T6-830-G12-35-Watt-HID-Bulb-ISO-9001-14001/303171377744
Re: 35/39w Open Rated CMH Lamp « Reply #2 on: November 15, 2020, 02:55:42 PM » Author: joseph_125
Thanks, but yeah it seems like my hunch is right. It's nearly impossible to find a open rated 35/39w CMH lamp in a non reflector format.
Re: 35/39w Open Rated CMH Lamp « Reply #3 on: November 15, 2020, 02:57:36 PM » Author: sol
I use standard G12 or G8.5 lamps enclosed in vapour proof fixtures for table lamps and such. A bit bulky but I have never found or experimented with something smaller...
Re: 35/39w Open Rated CMH Lamp « Reply #4 on: November 15, 2020, 03:14:44 PM » Author: joseph_125
Yeah I was thinking that a scaled down vapour tight globe would be perfect for enclosing a G8.5/G12 lamp without it being too bulky.
Re: 35/39w Open Rated CMH Lamp « Reply #5 on: November 15, 2020, 06:23:03 PM » Author: sol
I have only ever used 150W incandescent vapour proof for 20W or 35/59W CMH. I have thought about smaller vessels, but my ideas seem to run dry. Maybe a small Mason jar would work, but I haven't gotten around to it. I'd like to have a 20W in a glass chimney table lamp with a shade over it, but I need to find a bottle that is strong enough yet small enough to go into the chimney. Also, a small Mason jar would most likely fit properly in a conventional harp for a standard lamp shade, too.
Re: 35/39w Open Rated CMH Lamp « Reply #6 on: November 15, 2020, 06:31:00 PM » Author: wide-lite 1000
 How about a empty spice bottle ? They're maybe 1" wide .
Re: 35/39w Open Rated CMH Lamp « Reply #7 on: November 15, 2020, 06:33:50 PM » Author: sol
Well, if they can take the heat and I could find a suitable metal cover, that would work.
Re: 35/39w Open Rated CMH Lamp « Reply #8 on: November 15, 2020, 08:22:58 PM » Author: joseph_125
Yeah that might work, especially with the lower wattage lamps that shouldn't get too hot.
Re: 35/39w Open Rated CMH Lamp « Reply #9 on: November 15, 2020, 08:27:14 PM » Author: sol
I would certainly not exceed 35/39W with a spice bottle. 50W lamps and above are available in ED17, so I would use that for higher wattage.
Re: 35/39w Open Rated CMH Lamp « Reply #10 on: November 28, 2020, 01:37:06 AM » Author: Lumex120
Slight bump, but there is this one lighting manufacturer that I think might make what you are looking for. They have a lamp listed in their catalog as being a 35 watt metal halide lamp with a medium base, while making no indications that it's a reflector lamp. I have no idea what the lamp actually looks like and the picture is obviously wrong. This same company has 35 watt metal halide listed as an option on some of their fixtures so I kind of wonder if it's a proprietary thing. I've known about these for a few years and have always been curious to know what they are actually like. For all I know, it's just a standard quartz lamp but in some weird 35w size.
Here's a link to an Amazon listing, but it's kind of expensive at $49.
https://www.amazon.com/Dabmar-Lighting-DL-MH35-Medium-Halide/dp/B01L8Q4JME
Here's the catalog "page" where it's listed.
http://dabmar.com/specs/DL-MH35-DL-MH1000_SPECS.pdf
There's also a dual arc version available apparently, and I suspect the image on this one might actually show the dual arc version of the 35w lamp, and it looks like it's quartz and not CMH. Still would be really interesting to have one though.
http://dabmar.com/specs/DL-MH35-DA-50K-DL-MH70-DA-50K_SPECS.pdf
« Last Edit: November 28, 2020, 01:42:13 AM by Lumex120 » Logged
Unofficial LG Discord
Re: 35/39w Open Rated CMH Lamp « Reply #11 on: November 28, 2020, 12:43:38 PM » Author: joseph_125
Interesting find. The twin arc tube 35w looks really interesting. Too bad it's so expensive though.
Re: 35/39w Open Rated CMH Lamp « Reply #12 on: November 29, 2020, 04:42:11 AM » Author: Medved
It is expensive because it is a niche product. Plus I somehow doubt the dual arctube would do much except fast hot restrike, because MHs tend to leak arctubes at EOL and so cause glow discharge in the outer. I'm afraid in that case the glow discharge will shunt the ignition pulse to a too low voltage for tye other tube to ignite and take over.
But in fixtures like wall packs or bulkheads you may get the same effect by just using two sockets and connect two regular lamps in parallel, it will become cheaper...
Re: 35/39w Open Rated CMH Lamp « Reply #13 on: December 06, 2020, 08:21:26 AM » Author: WorldwideHIDCollectorUSA
A y-shaped socket adapter can replicate such effect pretty well.
Re: 35/39w Open Rated CMH Lamp « Reply #14 on: December 06, 2020, 10:28:35 AM » Author: sol
Yes, but where to find a porcelain pulse rated one ?
