Author Topic: Does blue incandescent light cause sleep issues?  (Read 3079 times)
WigWag
Does blue incandescent light cause sleep issues? « on: November 08, 2020, 06:59:54 PM » Author: WigWag
We all know cellphone screens, tv screens and computers can disturb sleep, but I'm curious if this also applied to incandescent light? As a kid, I recall GE & other manufacturers had 4w nightlight bulbs in both pink and blue. Perhaps this was before science showed blue light affected sleep. I just wonder if this applies to incandescent and if it depends on if the bulb is transparent or coated?
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: Does blue incandescent light cause sleep issues? « Reply #1 on: November 08, 2020, 09:06:50 PM » Author: Binarix128
There will be no more blue light in its costed or painted version than the original clear version, but your eyes will see only the blue light. Even will the same amount of blue light, that quantity of blue light is infamous compared with the amount of yellow and red light. When you only leave the blue light, the eyes "automatic gain control" will do its job and the blue light will appear brighter, and so the problem will come. It is not actually the quality in lumens for example of blue light that makes the problem, it is actually the quantity of blue light compared with the amount of other wavelengths.
It might sound a little confusing because I'm not too good choosing the English word for explaining something a level more complex, so I hope someone can explain it better.
« Last Edit: November 08, 2020, 09:17:43 PM by Binarix128 » Logged
Re: Does blue incandescent light cause sleep issues? « Reply #2 on: November 08, 2020, 11:02:54 PM » Author: WorldwideHIDCollectorUSA
I do know a good deal of Spanish, can you respond to me with your explanation in Spanish so that I can try to interpret what you are trying to explain?
Patrick
Webmaster
LightingGallery
Re: Does blue incandescent light cause sleep issues? « Reply #3 on: November 08, 2020, 11:11:44 PM » Author: Patrick
True, your pupils would dilate less with the white lamp due to it being brighter overall, and as a result take in less blue light.  However, I wonder if the difference is significant to have any meaningful impact on sleep disruption.  I use red bulbs in my nightlights, which would emit far less blue light in total.
Patrick C., Administrator
Binarix128
220V AC 50Hz, NTSC
Re: Does blue incandescent light cause sleep issues? « Reply #4 on: November 08, 2020, 11:17:36 PM » Author: Binarix128
That's what I wanted to say, you'll not take much blue light with an incandescent bulb because all the other light will make your pupil to close, while only letting the blue light pass will make your pupil open and take more blue light.
I use a 40w incandescent dimmed at 5-25% percent of the brightness, so virtually I take no blue light.
Re: Does blue incandescent light cause sleep issues? « Reply #5 on: November 09, 2020, 01:19:25 AM » Author: Medved
It is the sae as any other blue ich light. The issue is not that much with the pupil, but in "convincing" the brain you are not inside of your safe den or close to your protecting fire pit. So keeps you alert for danger and that way prevents you from sleeping well. Yes, (...) sapiens is not sleeping in dens for 1000's of years, but this is millions years of evolution. And we are not using fire for artificial light barely 100 years...
Re: Does blue incandescent light cause sleep issues? « Reply #6 on: November 09, 2020, 03:04:16 AM » Author: WorldwideHIDCollectorUSA
I inagine any type of low pressure sodium lamp can replicate the warm glow of fire very well and I feel very relaxed by the glow from low pressure sodium lamps.
Binarix128
220V AC 50Hz, NTSC
Re: Does blue incandescent light cause sleep issues? « Reply #7 on: November 09, 2020, 09:03:44 AM » Author: Binarix128
Yep, most HPS bulbs will work, also four incandescent bulbs in series will do the effect.
Re: Does blue incandescent light cause sleep issues? « Reply #8 on: November 09, 2020, 03:35:21 PM » Author: Ash
The answer would depend on the quality of the filter applied to the lamp - How much it attenuates wavelengths outside of the blue band pass, so how saturated the color is
Re: Does blue incandescent light cause sleep issues? « Reply #9 on: November 09, 2020, 06:24:26 PM » Author: WorldwideHIDCollectorUSA
What about wiring 4 120v incandescents in series as well to get the same effect.
Binarix128
220V AC 50Hz, NTSC
Re: Does blue incandescent light cause sleep issues? « Reply #10 on: November 09, 2020, 06:48:01 PM » Author: Binarix128
Yep, or even better. You can choose what power of incandescent you want more easily, you can add or rest bulbs as you want.
Binarix128
220V AC 50Hz, NTSC
Re: Does blue incandescent light cause sleep issues? « Reply #11 on: November 09, 2020, 09:21:22 PM » Author: Binarix128
Even if filtered incandescents are not the purest colors, that will still cause sleep problems to you.
Re: Does blue incandescent light cause sleep issues? « Reply #12 on: November 10, 2020, 03:37:41 PM » Author: Ash
Most filters applied to GLS lamps are very wide band pass, so no problem with the spectrum itself. If the light is "unsaturated" enough and not too bright, it's unlikely to cause any problems, not any more so than Moon light entering through the window...
Binarix128
220V AC 50Hz, NTSC
Re: Does blue incandescent light cause sleep issues? « Reply #13 on: November 10, 2020, 04:23:43 PM » Author: Binarix128
Sleeping with any light saturated with blue even the moon isn't going to help you sleep too much.
Re: Does blue incandescent light cause sleep issues? « Reply #14 on: November 10, 2020, 04:42:05 PM » Author: Medved
There is no health difference if the blue is saturated or not at all. Either causes the same stimulation, which is good once you want to wake up for an activity, but bad if you are about to go to sleep.
Claiming the "narrowband" to be "more dangerous" is a plain hoax, coming from complete misinterpretation of the original warning (pointing to risks with the LEDs in the bedrooms at time the LEDs were just the 6000+K and virtually only wide spread in low power night lights).
It meant any high CCT light source.
Such high CCTs were practically never used at homes before LEDs, so obviously the sleeping problems came only when the LEDs spread these high CCT lights to homes.
It were journalists, who did not understood a thing technical from the article (surprise, surprise,...), fliped the message over and portray the LEDs as the biggest evil...
